karlak
| posted on 29/3/11 at 02:57 PM |
V6 Duratec engines
While looking for a 2litre Duratec, I have come across loads of Duratec V6's. These are much cheaper than their 2litre equivalent.
Can these be fitted in a 7 type car ? I am guessing the reason they are cheap as they can't, but also quite heavy I guess ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
coyoteboy
| posted on 29/3/11 at 03:18 PM |
http://img377.imageshack.us/i/kif1970ln2.jpg/
RazMan
| posted on 29/3/11 at 03:24 PM |
They are about the lightest V6 at 160Kg and you can mate it up to a heavy duty Type 9, Jag or Cosworth T5 box - they go nicely with throttle bodies
too
[Edited on 29-3-11 by RazMan]
Raz
beagley
| posted on 29/3/11 at 03:28 PM |
I was curious of this too, here in the States the 3.0L v6 duratec is about half the cost of the 2.0L i4. I was trying to figure out why. I've
seen some impressive numbers from lightly modded 2 liter lumps so I imagine the 3 liter would be even better. Anyone on here brave enough to tackle
the v6 yet?
Beags
I'm not scared!!! I'm just marking my territory.
| posted on 29/3/11 at 03:29 PM |
Speak to Clairtoo about them... she knows her stuff!
It's Evolution Baby!
ChrisW
| posted on 29/3/11 at 03:31 PM |
You need a Jag S-typre gearbox I believe to make them RWD, which is where the cost becomes an issue.
Chris
coyoteboy
| posted on 29/3/11 at 03:47 PM |
Shame they're relatively low power in stock form, for their weight though. I suspect it would take quite a bit of £££ to put much more than 220
out of the crank? Hence the lower price than performance 2 litre engines?
RazMan
| posted on 29/3/11 at 03:49 PM |
I had 202bhp out of the stock ST24 version and 230 bhp (and buckets of torque) can be coaxed out of them with relatively simple mods. They sound nicer
than a 4 pot too
Raz
coyoteboy
| posted on 29/3/11 at 04:19 PM |
They do sound good
clairetoo
| posted on 29/3/11 at 05:29 PM |
Sorry - it's the Mazda KL V6 I play around with (as used in Mx6 , Ford Probe and a few other cars...) - it's close to 80mm smaller in all
directions than the Duratec lump , and somewhat lighter too at 110kgs bare.....
Its cuz I is blond , innit
Claire xx
Will weld for food......
flak monkey
| posted on 29/3/11 at 07:07 PM |
They are cheap as there arent any tuning bits available cheaply. Its OK if you are happy with what the standard engine gives on throttle bodies.
Beyond that it gets very, very expensive.
Sera
http://www.motosera.com
RazMan
| posted on 29/3/11 at 08:05 PM |
I was thinking of some reprofiled cams to make things a bit more nippy. I had a word with one of the cam companies and they reckon they can get an
extra 1mm of lift with a bit more overlap. The cost of a reprofile isn't too bad - about £200 IIRC.
I lightened my flywheel too and it really revs quickly now.
Agreed, that is about all I can afford to do ..... but then I saw a lovely supercharger from a Lexus V6 which would look really pretty sitting on top
of it
Raz
beagley
| posted on 29/3/11 at 08:22 PM |
You all are making it increasingly difficult to get any work done with all this talk of more cylinders, valve overlap, forced induction, cam
grinding.... sheesh!
Beags
| posted on 29/3/11 at 08:24 PM |
Oops... I'm getting my V's confused!
