Author: Subject: How do I know which blade engine I have ??
tompat3463
posted on 31/3/11 at 08:02 PM Reply With Quote
Bought MK INDY-Blade few weeks ago and am wanting to make some changes to the engine setup. i.e. dynajet. filters etc.
Trouble is I don't know which engine model I have as I didn't build it..
I know its got magnesio or something on the rocker cover but don't they all ??
Its got carbs but so do loads of them.
What else can determine which engine I have ??
Also where is the best place to but DYNAjets and how easy are they to install and setup ??
TIA Alan
doddy
posted on 31/3/11 at 08:16 PM Reply With Quote
it should say the cc on the side of the engine 839 918 or 919 i think they are
McLannahan
posted on 31/3/11 at 08:17 PM Reply With Quote
Can you find the engine number? It's near the clutch cover plate.
HappyFather
posted on 31/3/11 at 09:24 PM Reply With Quote
As McLannahan said, find the engine number.
It's 2 letters, 2 numbers, one letter, dash, 7 numbers.
Except for bikes up to 1994, the "xxnnx-nn" are enough to tell the year/model.
example, UK CBR900RR 1998 is "SC33E-22nnnnn".
Put your initial here and I can look it up on the Haynes manual.
HappyFather
tompat3463
posted on 31/3/11 at 09:51 PM Reply With Quote
ok thanks for the advise will look at engine number. where will it be located exactly ??
Alan
McLannahan
posted on 31/3/11 at 10:03 PM Reply With Quote
Alan
Alan, if you can trace your clutch cable you'll see this attaches to the small clutch arm. A few inches away from this is a small flat surface (inch by 3 inches). The engine number is stamped into this and takes the form HappyPapa has posted above.
Hope that helps. If you get stuck I'll take a photo and point it out a little better than my description!
mad-butcher
posted on 1/4/11 at 09:26 AM Reply With Quote
Wouldn't bother, just enjoy it, It's fast enough to get you a 12 month ban and more than fast enough for a good trackday session, as I've said many times before " would old man Honda have spent millions designing an air box for the blade if a 50p bit of foam worked better" still it's not my car or money, I spent mine on a set of 888's
tony
