mad4x4
| posted on 7/4/11 at 08:32 PM |
Megasquirt - RS232 to USB Cable
Anyone know where I can by a cable that WILL work with megatuner and tunerstudio
Have had a few in the past and coudn't get them to work eventually got a PCMCIA to rs232 adapter and used that howevery my laptop has now died
and the new windows 7 one I bought doesn't have PCMCIA or PCExpress on it so I need a USB to RS232.
Anybody recommend a link to one that defo works.
Scot's do it better in Kilts.
liam.mccaffrey
| posted on 7/4/11 at 08:37 PM |
We have a piece of test hardware in work that has a serial interface and I have never got a usb to serial adapter to work with windows 7.
We had to buy a Win XP laptop with a serial port in the end.
Build Blog
Build Photo Album
coyoteboy
| posted on 7/4/11 at 09:10 PM |
I bought a cheap £1.85 RS232>usb cable for my laptop... this exact one:
http://tinyurl.com/47bvh46
and it has worked flawlessly (other than the slightly annoying fact that whenever you unplug/replug it changes port number, but thats a minor
issue).
I wonder if, because mine's an MS1, the MS2 faster data rate causes issues with the USB transmission method, but I can't see it. Good
luck
J
[Edited on 7/4/11 by coyoteboy]
mad4x4
| posted on 7/4/11 at 09:12 PM |
Yeah if I was doing this at work I'd use a desktop with a serial port on my old D630 laptop or a PCMCIA card, but at home I'll need a 232
to usb converter.
Getting a new laptop at work as well so think my old d630 will be going back to IT soon so loose the com port on it as well
RazMan
| posted on 7/4/11 at 09:21 PM |
I got one of Maplin's cheap serial/usb cables. It works perfectly on my Win7 netbook after a bit of driver updating and port configuring -
nothing fancy. I use Easimap but it has the same port handling code as anything else AFAIK.
Raz
ashg
| posted on 7/4/11 at 09:28 PM |
second vote for the maplins one. i have both the blue and black maplin ones both work with no bother.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
RichardK
| posted on 7/4/11 at 09:36 PM |
This one maybe??
USB adaptor cable for Megasquirt Megajolt + other ECUs on eBay (end time 02-May-11 21:19:23 BST)
Rich
Gallery updated 11/01/2011
blakep82
| posted on 7/4/11 at 11:45 PM |
i seem to remember that the issues with some adapters not working was down to com port settings? and MS/MJ not looking for the same COM port on the
computer as the usb device was automatically set to?
i really think 'almost' all of them do actually work ok
________________________
mad4x4
| posted on 8/4/11 at 06:11 AM |
Well maplin is on the way home so i'll pop in there and see what they have.
RazMan
| posted on 8/4/11 at 03:19 PM |
+1
Raz
jeffw
| posted on 8/4/11 at 03:54 PM |
I've had a Belkin one for years and it is the only one that I've had work with everything...
ed1801
| posted on 8/4/11 at 04:50 PM |
1 quick thing, I had a standalone usb to 232 converter. It wouldn't work when i plugged it into the megasquirt with a long usb cable. When I
plugged it into the laptop directly with a long 232 cable to the ms it worked fine.... Don't understand!!!
matt_gsxr
| posted on 8/4/11 at 04:55 PM |
issue).
luck
J
I've got one of those two. I had to get the drivers from the fdti site, but it works fine on my netbook under win7.
Tunerstudio can't autodetect it, but I think that button has never worked. I run portcheck.exe to confirm its all fine before starting
tunerstudio.
Matt
