Author: Subject: Do I really need ARP bolts?
Nitrogeno25
posted on 17/4/11 at 03:36 PM Reply With Quote
I plan to use a lightened raceline flywheel in my duratec installation (looking for 170-180bhp). I have a set of new stock flywheel bolts I bought from Burton, but I've been advise to use ARP bolts.
Do I really need to go for the ARP bolts (40-50 for a set)?
Thank you!
marcjagman
posted on 17/4/11 at 03:46 PM Reply With Quote
They are much better. Higher torque settings and stop the end caps from moving around due to better shoulders.
whitestu
posted on 17/4/11 at 03:50 PM Reply With Quote
My blacktop has been over 8k a couple of times on standard bolts and still works!
Stu
blakep82
posted on 17/4/11 at 03:52 PM Reply With Quote
they've got their benefits, but do you really NEED them? no of course not. but putting them in should give you higher rev limit
________________________
DIY Si
posted on 17/4/11 at 04:20 PM Reply With Quote
Only if the flywheel bolts are what limit the revs on a stock engine. And I doubt they do.
Sun Tzu, The Art of War
posted on 17/4/11 at 05:14 PM Reply With Quote
End caps on a flywheel??
Would have thought that with a lighter flywheel and a much lighter car than the engine was originally fitted to the flywheel bolts would be less stressed even at higher RPM BUT is it worth the risk ???
FASTdan
posted on 17/4/11 at 06:57 PM Reply With Quote
We went for new standard flywheel bolts on ours. As has been said light car etc means they should be well within their safety factors.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
omega0684
posted on 17/4/11 at 07:53 PM Reply With Quote
i have ARP's on big end and flywheel, more for peace of mind than anything else.
Tiger Super Six
posted on 17/4/11 at 08:14 PM Reply With Quote
Note, if you go for the standard ones they need to be shortened.
Mark
Tiger Avon
Nitrogeno25
posted on 18/4/11 at 03:55 PM Reply With Quote
Thank guys,
This are the ones i got: http://www.burtonpower.com/pr6597.html
Do I need to shorten them?
Thanks again.
