| posted on 18/4/11 at 01:40 PM |
Dellorto dhla 40set up for 1660 tuned crossflow
What are the jets/tubes etc recommended for a 1660 crossflow?
brief spec.
- 1660 engine with 1300 pistons so higher CR
- ported head with larger inlet and exhaust valves
- BCF 2 camshaft on vernier gear
- tubular exhaust
twin dhla 40 carbs.
The jets/tubes what I have currently fitted do not match what I find nthe web nor what is recommended in the Weber/Delorto book.
cliftyhanger
| posted on 18/4/11 at 01:46 PM |
Can't really help BUT be careful, lots of the DHLA's are emission versions. Not a problem except they need tuning differently. Mine went a
while ago, and all they needed was the idle jet increasing up to 62 from 55 (that was on an 1800 zetec)
Post up the version, I may have some info dug away somewhere.
kipper
| posted on 18/4/11 at 01:49 PM |
buy my Webber's + manifold ready set up for crossflow. See for sale section.
Denis.
Where did that go?
thunderace
| posted on 18/4/11 at 07:06 PM |
ok what do you have???
norfolkluego
| posted on 18/4/11 at 07:25 PM |
When I had a Crossflow I had my Dellortos sorted by our local carb expert
His set up was
Chokes 30mm
Mains 135
Idles 58
Airs 200
Pumps 40
Emulsions 7772.11
That was on a 1.6, ported head and a Burton A2 cam.
Hope that's of some use
| posted on 20/4/11 at 09:20 AM |
My current set up is:
Chokes 32mm
Mains 148
Idles 57
Airs 210
Pumps ??
Emulsions 7772.11
so surprisingly similar and quite different to what the book says, hmmmm...
