Author: Subject: Which Pedals for a Hydraulic Clutch.
karlak
posted on 23/4/11 at 06:34 AM Reply With Quote
I really need to get my list of things to buy together for the Pinto to Duratec change.
Next on the list is the Pedals. It looks like a change from Cable to Hydraulic clutch is on the cards. I seem to have a very basic pedal set in my car, with a cable clutch.
Just curious what you guy have used who have a hydraulic clutch set-up?
Also,, sorry to go over old ground. The flywheel and clutch needed for the Duratec... Can I not just use a complete flyweel and clucth setup for the ST150 ? I am getting a bit confused over the required bits, it all seems to be a bit of mix'n'match at the moment..
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
bj928
posted on 23/4/11 at 07:09 AM Reply With Quote
I have tilton, you can go on their web site and put in details of your system and they will list the correct master cylinder for your application , bit expensive, but i bought from America and saved £300 over the price from demon tweeks.
posted on 23/4/11 at 07:34 AM Reply With Quote
Suspect it really depends on what pedal box you are using?
