Stuart_B
| posted on 29/4/11 at 06:07 PM |
zx9c carbs
hi all, just wondering does anybody know where the air correction jets are on these carbs???
trying to set up the zx9c carbs for a mid tuned pinto, any ideas on starting settings?
cheers
stu
jacko
| posted on 29/4/11 at 06:21 PM |
The air screws are under the carbs up some small tubes on zx9r /E carbs so i think they will be in the same place on your carbs
Or do you mean the ones you block off some times depending on the engine set up ?
Stuart_B
| posted on 29/4/11 at 06:40 PM |
yes jacko the ones you block off
stu
jacko
| posted on 29/4/11 at 06:53 PM |
In this photo its the little brass jet holes at the top of the 2 brass holes you see the ones that you block are inline with the main needles
Are you sure yours need blocking ? not all setup need these blocked
Stuart_B
| posted on 30/4/11 at 06:57 AM |
cheers for the picture i will try and compare them to mine.
i do not know if i need to block them off, just that i have read in a lot of places you need to block them of.
cheers
stu
