Author: Subject: blacktop to T9
AndyW
posted on 10/5/11 at 01:38 PM Reply With Quote
blacktop to T9
OK tried a search and found most the answers Im looking for. I have a blacktop 2.0 zetec being married to a T9. Im using the standard blacktop flywheel and clutch. (Cheaper and easier as already got it, upgrade later)
Question is, as Im using the standard clutch and flywheel, what else is needed. Im ready to put engine and box in so if I need any other parts I need to order them quick.
mrwibble
posted on 10/5/11 at 02:05 PM Reply With Quote
i found this interesting reading, http://www.zetec-cat.co.uk/ i'll be interested in how you get on as i'll be doing the same thing at some point.
how you going about fueling / planning on passing emissions?
SeaBass
posted on 10/5/11 at 02:06 PM Reply With Quote
cct133 release bearing - clutch arm for the T9 box.
Norfolkluegojnr
posted on 10/5/11 at 02:23 PM Reply With Quote
you'll also need a spigot bearing for the zetec - this will mean removing the flywheel and clutch to fit it, so you'll need a new set of flywheel bolts too - i'd recommend using ARP bolts for security.
I'd also recommend using a 1.8 zetec flywheel as its lighter and will spin up quicker. It'll take the 2lt clutch (i know as thats what i used).
so:
spigot bearing
CT133 release bearing (thicker than the standard sierra item)
ARP flywheel bolts
you'll be good to go
AndyW
posted on 10/5/11 at 02:48 PM Reply With Quote
Using the original ford ecu/injectors fuel rail on a custom inlet from GBSC
femster87
posted on 10/5/11 at 05:35 PM Reply With Quote
I used the cct303 spigot bearing and my clutch seemed to work ok. not driven yet
posted on 10/5/11 at 06:51 PM Reply With Quote
Since when? theres a hole in the crank to fit a spigot bearing so no need to remove the flywheel
big_wasa
posted on 10/5/11 at 07:22 PM Reply With Quote
Any pics of that manifold please. I am being nosey.
Norfolkluegojnr
posted on 10/5/11 at 07:41 PM Reply With Quote
you're right. the memory aint what it used to be.......
still worth swapping for a 1.8 flywheel though. .
