johnq
| posted on 14/5/11 at 01:02 PM |
type 9
can anybody tell me what covers the end oof the tailhousing, looks like some sort of plate is missing at the gear lever end??? also where to get a
replacement ive searched everywhere, thanks in advance
looks like rain again
omega0684
| posted on 14/5/11 at 01:07 PM |
nothing thats where you stick the prop in!
| posted on 14/5/11 at 01:09 PM |
If you mean the cover just behind the gear lever above the prop then it's just a thin core plug like part. It may still be possible to get one
from Fords or Burtons? A plastic disc cut to fit and held in with a bit of Areldite ,silicon etc would do the job just a well
| posted on 14/5/11 at 01:10 PM |
Wrong!
tomgregory2000
| posted on 14/5/11 at 01:25 PM |
its not needed as that is where your gearlever extension goes through, nothing will fall out
| posted on 14/5/11 at 01:37 PM |
As above - it's just something to keep the dirt out of the mechanism at the bottom of the gearstick. I'd cut a bit of aluminium to fit,
then stick it in with silicone (don't use epoxy, as you may want to get it out again).
omega0684
| posted on 14/5/11 at 01:40 PM |
Wrong!
my original one was a joke hense the " "
im well aware,he means the cover plate that allows access to the selector linkage, just left mine open as it kept falling out!
johnq
| posted on 14/5/11 at 01:44 PM |
Thanks everybody for your quick replies, and "humour" do you pack this area with grease????
omega0684
| posted on 14/5/11 at 01:57 PM |
no need to "pack" with grease, i have just made sure the interlocking parts of the linkage are well greased.
