Author: Subject: Radiator required to fill space 700x280mm, suggestions?
MK9R
posted on 15/6/11 at 06:12 AM Reply With Quote
Since new engine install the old polo rad isn't up to the job, i've already increased the oil cooler size and improved the ducting but its just not working. I have an available space of 700mm wide x 250 high, obviously i can incline it to take a higher rad. Ideally i'd like a lightweight alloy rad, but also i dont want to spend a fortune (as there is a good chance it will get fubared soemtime soon . I've been looking round and a mkII MR2 rad looks like it may just fit, but i've not got exact dimensions. Any other suggestions??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
HowardB
posted on 15/6/11 at 06:27 AM Reply With Quote
how about two smaller rads? maybe two bike ones, might be a more flexible solution,...?
hth
Howard
gavin174
posted on 15/6/11 at 07:10 AM Reply With Quote
this any good..
Westfield VW Polo Alloy Radtec Universal Radiator | eBay UK
direct replacement and not that expensive
MK9R
posted on 15/6/11 at 07:25 AM Reply With Quote
not at that price The polo rad just isnt a nice fit in the front of my modified fury front end, which is partly the reason for the bad air flow IMO
Cheers Austen
RGB car number 9
www.trackace.co.uk
Dingz
posted on 15/6/11 at 07:28 AM Reply With Quote
Just a thought are you sure that you have enough holes to let the hot air out? are you getting a good airflow through the existing rad?
went on and on.
MK9R
posted on 15/6/11 at 07:31 AM Reply With Quote
Yeah flow is fine, removed undertray in engine bay as thought this was partly to blame. The rad is also a bit battered so think this is another factor, but the fact is the car always ran nice a cool with the blade engine, but the new. R1 is gettimg too hot, so purely gotta be rad isn't upto the job
Cheers Austen
RGB car number 9
www.trackace.co.uk
rachaeljf
posted on 15/6/11 at 08:43 AM Reply With Quote
A VW Scirocco rad is the one we X1/9 owners go for, light and cheap. The Punto GT is another possibility.
Cheers R
stevebubs
posted on 15/6/11 at 08:48 AM Reply With Quote
Austen,
You have mail with a radiator sizing csv...has sizes for most rads in it...
Personally I just went down to the local motorfactors and looked through their Valeo catalogue...
Stephen
stevebubs
posted on 15/6/11 at 08:50 AM Reply With Quote
PS I ended up with a Seat Cordoba rad for my Fury...keeps my zetec nice and cool and is a very good fit behind the grill...
hughpinder
posted on 15/6/11 at 08:56 AM Reply With Quote
I bought one for a ford focus (575*225) which is all alloy cores with decent gap between fins. There was a stand at Newark selling a whole host of rads. Mine was £15 (new)
The other possibilities for the engine getting too hot are:
Water pump not giving good flow.
Insuffient coolant in the water.
Thermostat stuck/blocked.
Airlock so engine isn't fully cooled.
Fan seized or running the wrong way.
And probably a host of other cooling things - could also be incorrect timing/fueling causing the engine to produce too much heat too.
I'm assuming you would have spotted kinked or collapsed pipes/hoses.
Regards
Hugh
MK9R
posted on 15/6/11 at 10:47 AM Reply With Quote
Thanks all, looks like a 205 one will fit nicely!!!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
James
posted on 15/6/11 at 03:06 PM Reply With Quote
The Mk2 Golf rad is same hose sizes etc. as Polo but 50mm wider. I used this one myself just to be future-proofed in case I upgrade engine and need the cooling.
Also, according to PPCmag article on cooling/rads if you set the rad top at 20° back from vertical then you get much better cooling as the cool air can reach the rear core of a twin core without being so blocked by the front core!
HTH,
James
ss1turbo
posted on 23/6/11 at 06:58 AM Reply With Quote
Originally posted by stevebubs
Austen,
Stephen
Without being cheeky...any chance of a copy of the file? Would give me a starting point (was doing a search for an online radiator catalogue and this thread popped up). Does it have cooling capacity (need one for a X30XE Vauxhall lump) listed, or just the original application?
Phil
Long live RWD...
SausageArm
posted on 24/6/11 at 06:20 AM Reply With Quote
Vauxhall Corsa uprated alloy radiator, 280mm high, 620mm wide, 43mm thick
Vauxhall Corsa Uprated Alloy Radiator GSi Turbo C20LET | eBay UK
