Fishface
| posted on 16/6/11 at 12:40 PM |
Buying an oil catch tank for a silvertop zetec
There seems to be two types of catch tank one with an air filter and one without. My thinking is if i connect the cam cover outlet and the crankcase
both into a catch tank there is no way of releasing gases. If i get one with an air filter this would be safest. What do people recomend?
whitestu
| posted on 16/6/11 at 01:39 PM |
Why do you need a catch tank? My breather goes into the air filter, but never seen much coming out of it.
Stu
scutter
| posted on 16/6/11 at 03:21 PM |
I run a one litre Mocal one, as Stu says, i never get anything out of it bar moisture.
ATB Dan.
big_wasa
| posted on 16/6/11 at 04:00 PM |
I've got a 1 L obp tank. Three in/out puts.
will121
| posted on 16/6/11 at 04:39 PM |
It will need to be vented to atmosphere some where, I have a 1 litre tank fitted with two tappings, you could tee the cam cover breather and crank
case together to one connection and then fit a small breather filter to the other, will try post picture later
[img] [/img]
[Edited on 16/6/11 by will121]
Dusty
| posted on 16/6/11 at 05:35 PM |
I use a red bull can with the breather pipe stuck in it. As you have dual breathers you could use two red bull cans or a red bull can and a coke can
or.....
Fishface
| posted on 16/6/11 at 08:48 PM |
I like your thinking....cheap but sort of cool.
Maybe then fit an air filter to the cam cover and the crank case to a redbull can!
