Author: Subject: can anyone help identify the year of this blade engine?
needforspeed
posted on 7/7/11 at 09:50 PM Reply With Quote
as titel really after a wiring diagram!
wylliezx9r
posted on 7/7/11 at 10:01 PM Reply With Quote
There should be some numbers on the engine, that would be better to identify the engine.
George Best
welderman
posted on 7/7/11 at 10:16 PM Reply With Quote
looks like an early one, 85/86, check cc size then you will get a better answer
Thank's, Joe
I don't stalk people
ReMan
posted on 7/7/11 at 10:21 PM Reply With Quote
As said engine number, it should tell you the cc on the block
I suspect early 893 though at a guess. Is the a TPS on the carbs?, is there a sensor onto the gearbox? (Not the neutral swithch)
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
needforspeed
posted on 7/7/11 at 10:23 PM Reply With Quote
thanks for the replys il double check tomo not even seen the motor yet just been sent some pics and asked to wire it and get it running! :-/
mark chandler
its got a sight glass so a 918/919 which makes it 1995 ish
It will run with any early blade spark ECU, if you fit a CBR600 you can rev it a little higher.
diagram
provide power to the ECU and earth the side stand and neutral wires.
Earlier engines did not have TPS's so ignore if not fitted.
needforspeed
posted on 8/7/11 at 08:30 PM Reply With Quote
thats perfect thanks!!
needforspeed
posted on 8/7/11 at 08:31 PM Reply With Quote
engine code was sc33e 27485 anyway!
McLannahan
posted on 8/7/11 at 09:03 PM Reply With Quote
My engine (sc33e 2xxxx) was a 1997 919cc.
