Craigorypeck
| posted on 12/7/11 at 08:53 PM |
why wont it just go!?!
Lost half a sump of oil yesterday.... Oil catch tank which is connected to the crank and rocker cover is getting filled with this
Started engine again this eve and after a few mins running see the pool of brown oil under the yellow valve.
Water level is full in the rad.. head gasket ?
What should I do before taking the head off... again, to help diagnose the prob?
NA YB BTW
austin man
| posted on 12/7/11 at 09:05 PM |
Did you have overheating problems if so the head may be warped
you can have it pressure tested they use a coloured dye to see whether there are gasses leaking into the water system.
[Edited on 12/7/11 by austin man]
garybee
| posted on 12/7/11 at 09:36 PM |
Have you done a comression test to make sure it's not 'blow by' gasses pushing it out?
Craigorypeck
| posted on 12/7/11 at 09:52 PM |
No over heating issues but wasn't going easy on the revs... C test tomorrow. broken rings maybe. *sighs*
Craigorypeck
| posted on 12/7/11 at 11:10 PM |
Did compression test all within 10psi bracket.
checked the head bolt torques and all seems fine, one is slightly suspicious but still clicks at 90lb/ft rest are 110.
Mark Allanson
| posted on 13/7/11 at 07:20 AM |
I would be checking the crankcase breathers are clear, pressure buildups can cause all kinds of weird symptoms
Craigorypeck
| posted on 15/7/11 at 06:38 PM |
You sir are quite right!!! Ta
