Author: Subject: to stud or not to stud that is the question?
Dopdog
posted on 13/7/11 at 12:01 PM Reply With Quote
Hi all
anybody used head studs instead of bolts? what do you think and is there an advantage of using them?
[Edited on 13/7/11 by Dopdog]
AndyGT
posted on 13/7/11 at 05:02 PM Reply With Quote
faster dismantling and re-assembly times are the only advantages I can see. Big disadvantage is that you will always have some threads exposed.
nothing is impossible
everything is possible
DIY Si
posted on 15/7/11 at 02:01 PM Reply With Quote
It also depends upon the engine. Some are designed to use modern stretch bolts, older engines tend to use studs. Personally, I;d use whatever the engine was designed to use.
Sun Tzu, The Art of War
