Author: Subject: Which Starter motor?
AndyG
posted on 15/7/11 at 01:37 PM Reply With Quote
Hi all,
I have a blacktop zetec to a type 9 with a cut down sump as I couldn't afford the raceline sump or similar I am struggling to fit the starter motor which I think is a Lucas LRS543.
I have grinded off quite a bit of the webbing on the windage tray but its still fouling on the lip between the windage tray and the metal sump at the bottom.
Therefore is there a slimmer starter motor I can use, which starter motor do people tend to use, as I am apprehensive to grind off anymore and instead thought I would look at a smaller starter motor.
big_wasa
posted on 15/7/11 at 02:53 PM Reply With Quote
Two differant manufactures of a starter fitting the same car can have slightly differant dimension of length and width. So not as easy as saying you need x, y z but the Lucas lr707 is often refered to.
