Author: Subject: Prop Shaft shortening.
karlak
posted on 24/7/11 at 08:12 AM Reply With Quote
It looks like I may be able to shorten the prop shaft by a couple of inches or so as part fo installing the Duratec. The Pinto always looked like it was quite a long way "forward" in the car.
Is it really worth doing this? I guess any weight moving towards the centre of the car has to be an advantage. I have a company fairly local who will both shorten and balance the prop. I suppose a balance is not a bad thing to do anyway.
I realise the Gearstick will move back also, but that is good, as it was always a bit too far away. Will I have any other issues in doing this/
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Ben_Copeland
posted on 24/7/11 at 08:51 AM Reply With Quote
Always best to try get the engine as far back as possible. Better weight distribution.
If you do shorten the prop make sure you get it balanced.
Ben
Locost Map on Google Maps
Enter Your Details Here
Ben_Copeland
posted on 24/7/11 at 08:55 AM Reply With Quote
if you do move it back, make sure you dont get too close to the handbrake as i find my handbrake is now in the way
[Edited on 24/7/11 by Ben_Copeland]
Ben
posted on 24/7/11 at 09:59 AM Reply With Quote
My Luego has a shortened Sierra handbrake lever which gives plenty of clearance even when used with a remote gearlever extension .
Ben_Copeland
posted on 24/7/11 at 10:21 AM Reply With Quote
How did u shorten it?
Found a how too
http://www.locostbuilders.co.uk/viewthread.php?tid=17423
Ben
posted on 24/7/11 at 11:20 AM Reply With Quote
I cut and shut mine when I did it but it was a while ago and I can't remember exactly how I did it but it only took an hour or so . Fiesta item may be usable and may be a bit shorter?
