AdrianH
| posted on 19/8/11 at 02:28 PM |
Help, Zetec nearside engine mount
Making up the plates to make the engine mounts for the 1.8 silvertop. Offside is OK I can see three triangulated points to fix the mounting, but what
is the recommended fixing on the nearside. I have three points in a line and a few more holes further away.
Adrian
[Edited on 19-8-11 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
mikeb
| posted on 19/8/11 at 02:39 PM |
from recollection you use the alternator bracket mounts on the front left of the engine.
Four bolts in a rectangle you can see two of them in your picture
Norfolkluegojnr
| posted on 19/8/11 at 02:40 PM |
On the left of your pic, where that plate thing is mounted. you can only see two bolts in the pic, but there are four on the block.
that's where mine is mounted.
AdrianH
| posted on 19/8/11 at 02:48 PM |
Oh that’s poo!
That is where I have mounted the alternator, that is a modified CVH alternator block fitted with the CVH alternator. It kept it away from the
steering shaft, oil filter and inlet plenum.
Wondering if I could do a wrap around bracket using the two bolts you see going into one of the three holes.
Would like to have the bracket mid way down the engine, but found it difficult to reason out.
Adrian
Norfolkluegojnr
| posted on 19/8/11 at 03:05 PM |
I'm sure you could use those holes, but it might be a bit trickier.
could you not fit the mount over the alternator bracket with long studs or bolts?
AdrianH
| posted on 19/8/11 at 04:13 PM |
Been looking and I could use the last two holes there and fab up a bracket I think.
I would have to mill the alt bracket I have to be flat over the two holes but that should not be a problem.
I have to get some plate for it, I have 10mm plate but suspect it is too thick, I would certainly struggle to weld that thickness up anyway.
I think the body of the alternator would get in the way of the engine mount if I mounted over the top?
Adrian
speedstar
I;m not necessarily saying to buy them, but you can use these to get an idea of where you can mount to
http://www.ekmpowershop9.com/ekmps/shops/gtstuning/engine-mounts---zetec-180-p.asp
AdrianH
| posted on 19/8/11 at 04:24 PM |
Speedstar. That is a good idea. the one on the left obviously sits where my alt bracket is so mine would have to be made to allow.
I need to take some measurements getting an idea of drop needed to go to my engine mounts.
Adrian
big_wasa
| posted on 19/8/11 at 04:55 PM |
I was going to say the gts has a two leg thing that you could make work. I would beef them up a little though.
avagolen
| posted on 19/8/11 at 08:00 PM |
Hi Gents,
Just jumping in on this thread as the photo of the engine in question shows the casting number 20C96 on the side.
Does anyone know what it means?
I would be interested to know as mine has been ground off !!!!
Len.
RichardK
| posted on 19/8/11 at 08:06 PM |
Mine seems to have another hole lower down??
Rich
Gallery updated 11/01/2011
slingshot2000
| posted on 19/8/11 at 08:39 PM |
Rich
Richard, your alloy alternator mount looks familiare, do you mind if I ask where you got it from and if it works ??
Regards
Jon
AdrianH
| posted on 19/8/11 at 08:47 PM |
But is there anything in that bottom hole or does it mate up with something on the alt bracket or on the sump?
Adrian
RichardK
| posted on 19/8/11 at 09:34 PM |
I made the alt bracket myself although couldnt squeeze my alt down there in the end so sold it on here, maybe thats where you saw it??, My sump is a
part ali sump so guess that has a bolt hole built in to in or I wouldnt have made it that way!!
Rich
