Author: Subject: Pinto Misfire & temperatures
davidimurray
posted on 2/9/11 at 07:26 PM Reply With Quote
Hello
I'm hoping I can pick up some tips from the vast knowledge base on the forum. I have two queries -
I've got my Pinto running now. It's an 1800 fitted with ZX6R carbs - jets are standard, needles are 1 below middle groove and idle screws are 3 turns out. This is all running with a Megajolt - timing has been set and checked and the map I have is one of the 'standard' base maps doing the rounds.
When the car is sat idling (it currently idles at about 1050 RPM) every 10/20 seconds I get a pop from the exhaust. You can hear it on this video here at 15 and 35 seconds - http://www.youtube.com/watch?v=6JVmMO2R4WY
If you watch the video further, when I raise the revs at about 40s second up until 48 seconds you can hear quite a few pops but they don't seem consistent. In the rest of the video I raise the revs further and the pops seems to decrease but there are lots coming off the throttle.
Has anyone got any suggestions on what could be causing this? An initial though I had could be air leaks into the exhaust?
Second question is about temperatures. Let the car get up to full temp. I've got a digidash and that shows that the engine fan comes on at about 105C and turns off at 98C. The fan switch is rated at about 75C so I am guessing this is just a function of the position of the fan switch against the temp sensor in the head. Does this seem like a normal sort of operating temp for a Pinto? If I hold the engine at 3500rpm for a few minutes, with the fan on the temperature sits happily at 101C so it would seem that the cooling system works.
Thanks in advance for your help.
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
jacko
posted on 2/9/11 at 08:20 PM Reply With Quote
Check you don't have a leak in the exhaust pipe it could be sucking air in to cause the popping
When you come of the throttle the popping seams to happen a lot when using bike carbs [ may be running to rich ]
you need a rolling road to set it up right
Jacko
snapper
posted on 3/9/11 at 05:43 AM Reply With Quote
I second the running rich theory, probably more to with the idle circuit and the progression holes than the main needle.
Temp is way to high for a Pinto, they should ideally run in the 80's not easy to achieve in a 7'n.
I fitted a thermostat that opens at 82 degrees and this helped enormously, a bit of creative ducting to force more air through the rad and I propped the rear of the bonnet 1/2" to help the hot air out.
Also fitted an oil cooler.
Have a spare 13 row, take off and oil stat if your interested.
I eat to survive
I drink to forget
davidimurray
posted on 4/9/11 at 09:55 AM Reply With Quote
Hello everyone
Had another play yesterday and made a discovery - I am an idiot :p
It seems while playing with the idle screws I had been turning them the wrong way and leaning out the mix rather than richening it up :eek:
Reset the carbs yesterday and it now runs a lot lot better although it still has the odd pop and bang on the overrun but that is probably an air leak. A wideband lambda is on the shopping list for tuning. I popped a CO meter up the can and at idle I was getting 1.5% CO.
For purely educational purposes I checked my shift lights were working as well - http://www.youtube.com/watch?v=SBZ497TwyII
On the temperature front I've been through the cooling system again and rebled it all and the engine now sits happily at 89C with the fan cutting in and out so it looks like I must have had an air lock somewhere.
Thanks for all the advice guys. I've whipped the exhaust off at the moment topolish it and wrap the headers in the engine bay so when I get it back on I will report how things are going.
Dave
