Moorron
| posted on 25/9/11 at 11:20 AM |
7" rebuild
Hi lads im after some advice on cost and if its possible to rebuild a Ford 7" diff.
Last year i took mine out of the car and ordered the rebuild kit after it was knocking, but after taking it apart i noticed most of the problem was in
the little spider gears on the inside of the unit and not the bearings which i ordered (i think).
Also i noticed that from under the car i can wiggle the output shafts just at the bolted joint to the driveshafts up and down which isnt helping but
im not sure how to rectify.
Should i just replace the bearings and washers which i now have AND/OR sort the spider gears too? What cost am i looking at for this if done by a
transmission builder?
This is my main winter project so am looking for early advice now so i can order or save some £'s up. Its a Ford 3.62 LSD with bolt on shafts.
Cheers.
ps F1 going to start now so hurry.
[Edited on 25/9/11 by Moorron]
Sorry about my spelling, im an engineer and only work in numbers.
jollygreengiant
| posted on 25/9/11 at 11:57 AM |
Are you sure it was the diff Knocking, not a drive shaft CV as these when worn can knock like bu&&ery. Although I suspect that having replaced
the diff you refitted the drive shafts.
Also, was it a knock from your diff when taking up drive and/or going on/off (drive to over run) the power?????.
| posted on 25/9/11 at 07:24 PM |
http://www.mc2racing.com/tech/20081104a/index.html
HTH if the link works
Moorron
| posted on 25/9/11 at 09:55 PM |
mmm nice link, but the problem i feel on my diff is the diff unit, which has small gears that rotate on solid metal pins, there seems to be alot of
play here.
I get knocking on both overrun and taking up drive but the problem which has me thinking its knackered is if i drive down a hill a dip the clutch and
then drive around a corner i get lots more rattling from the rear of the car from the diff.
