will121
| posted on 2/10/11 at 10:33 AM |
any tips on removing driveshaft hubs from gearbox?
im trying to fit a limited slip diff to my Fiesta, but i cant budge the drive shaft hubs out of the Diff, i had to split the CV joints to get the
gearbox out. they seem stuck fast of the ring in the hub, ive rried leavering, rotating it, tapping it but no joy.
is there any other tricks???
austin man
| posted on 2/10/11 at 10:53 AM |
if they are like the Modeo type they have a clip on them which locks into place when the shaft is pushed in, try more pressur or prising and tapping
with a hamme. Whe had to replace the rings they appear to be a one time use only as they deform when removed
NigeEss
| posted on 2/10/11 at 11:17 AM |
They can be a right bstrd to split.
Bute force and a crow bar usually works.
mcerd1
| posted on 2/10/11 at 12:14 PM |
they were a total PITA on my focus (IB5 box - so probably the same as yours)
bute force by means of 2 tyre levers, one from each side (me on on, my dad on thye other)
and even then we had to persuade it with coper hammer
will121
| posted on 2/10/11 at 01:29 PM |
thanks for all the info, got them out, big leaver and a bit of tapping with a rubber mallet
| posted on 2/10/11 at 02:06 PM |
Fork type ball joint splitter with a long handle --- gentle couple of taps to get the tip in then they will lever out OK
Silverline long handle Ball Joint Spliitter
| posted on 2/10/11 at 02:34 PM |
Better still is the correct tool, can't remember where I got mine from but I had it years . Looks similar to a ball joint splitter but wider
with a thinner taper
big_wasa
| posted on 2/10/11 at 03:46 PM |
I will have to get myself the tool. The last mondeo one I did took me a full day of buggering about before it poped.
mcerd1
| posted on 2/10/11 at 08:28 PM |
a slide hammer should do the trick if you've got an suitable end on it grip the shaft
(mine were so bad I actually started to make one of these... )
