Author: Subject: What diff - Sierra 2.0 GLS?
rb968
posted on 21/10/11 at 02:25 PM Reply With Quote
Can anyone enlighten me as to what diff was found in a 2.0l GLS Sierra?
I know its push in shaft which is what I want, been offered one someone has spare but its buried in a garage and I was trying to find out what ratio it will be. I currently have a 3.62 non LSD 7" sierra diff but its making some noise and got a lot of play on the prop flange (pinion)
Anyone know? Had a search but not found anything.
Rich
mrwibble
posted on 21/10/11 at 04:15 PM Reply With Quote
http://locostbuilders.co.uk/photos.php?action=showphoto&photo=Image1sml.JPG
see if that helps
mcerd1
posted on 21/10/11 at 04:49 PM Reply With Quote
most 2.0 cars had 3.92 - but the axle code on the vin plate will confirm that:
Ratio Code
3.14 M
3.36 A
3.38 V
3.62 U
3.64 3
3.92 D
also see here:
http://locostbuilders.co.uk/forum/9/viewthread.php?tid=85080
jacko
posted on 21/10/11 at 05:40 PM Reply With Quote
MY first diff come out of a 2L GLS and it was a 3,62 non lsd
I now have a 3.62 LSD fitted
Jacko
rb968
posted on 21/10/11 at 05:51 PM Reply With Quote
Thanks Jacko and others. Gives me some hope it may be the same as the one I have so I can swap it over. Just hoping its in better nick.
I m hoping to drop the existing diff out to have a better look at it, so might be after advice on whether its just knackered or even worth trying to rebuild.
For the £50 he is asking I am tempted to try this other one. Mine has lots of play on the prop flange. How much is normal?
Rich
DixieTheKid
posted on 23/10/11 at 09:36 PM Reply With Quote
In my 2.0 glsi it had a 7.5" open 3.14 with lobro's look on the vin plate for the axle type or get the code off of the tag on the back of the diff.
COS IT'S Worth IT
bertie_bas205
posted on 23/10/11 at 09:54 PM Reply With Quote
Ok, i have seen this in a few posts and have to ask.....
What the hell are/is lobro's/lobro?????????????
Bertie.
DixieTheKid
posted on 23/10/11 at 10:11 PM Reply With Quote
Bertie.
Bolt on output flanges
COS IT'S Worth IT
mcerd1
posted on 23/10/11 at 10:13 PM Reply With Quote
lobro's = the CV joints on bolt-on type driveshafts
they look like this inside:
tripod's = the CV joints on push-in type driveshafts
bertie_bas205
posted on 24/10/11 at 08:46 PM Reply With Quote
Cheers for that.....
Lobro's n Tripods..... Check....
Bertie.
