Bizarro
| posted on 24/10/11 at 02:43 PM |
Wood Auto starter
Ive got a 2.0 zetec blacktop with the 2 piece sump, Ive removed alot of the finning on the ally part of the sump (as per other posts) but the starter
I have still wont fit.
Found this at Wood Auto and it looks like it is quite a bit smaller than the standard Ford part, has anybody used one?
http://www.woodauto.com/Component.aspx?Ref=STR50041
AndyW
| posted on 24/10/11 at 03:22 PM |
Not used that started but I had to grind down the ally part quite alot. There was a lug that stuck out too, so that got grinded away and starter
fitted a treat. Sorry cant be any help with the starter in the link.
Bizarro
| posted on 24/10/11 at 06:32 PM |
Cheers for the reply. I have taken quite a lot of the original away, dont really want to grind any more
  sump
The problem is the starter is hiting the flange where the steel part meets the ally bit!
  starter
From the info I have I believe it is a Unipart starter motor and I think it is bigger than some of the other makes, loads of Sierra starters on
fleabay but I dont want to shell out more cash if Im not sure it will fit!
stevebubs
| posted on 24/10/11 at 06:52 PM |
Wuss!! Keep going...I'll see if I can find a pic of mine..
[Edited on 24/10/11 by stevebubs]
stevebubs
| posted on 24/10/11 at 06:56 PM |
Here you go...before I finished tidying up...
  Sump Before the tidy up
Bizarro
| posted on 24/10/11 at 07:06 PM |
Certainly taken more away than I have, looks like you broke through at the top, bit of ally welding needed!
stevebubs
| posted on 24/10/11 at 11:51 PM |
yup...got a bit over-exuberant!!
