johnemms
| posted on 2/11/11 at 10:49 AM |
Setting Ignition...
Ok.. so ...
I disconect the vaccum advance and block off manifold conector
I use strobe to set ignition to TDC 0 degrees at 650rpm
I reconect vaccum and check with strobe
It reads 12 degrees - 800rpm
Mechanical advance seems to start about 1000rpm
Turn off engine - restart - no kick back - seems ok..
have I missed anything?
cheers
jon
1690cc crossflow - Trying a single weber DCOE 40 - 32 choke
[Edited on 2/11/11 by johnemms]
MakeEverything
| posted on 2/11/11 at 10:56 AM |
Sounds about right to me.
Kindest Regards,
Richard.
johnemms
| posted on 2/11/11 at 11:39 AM |
Cheers... having a blonde moment....
Dingz
| posted on 2/11/11 at 01:25 PM |
Surely you need some static advance not just running at tdc? ignore the fact the vacuum is giving you some when it is connected.
went on and on.
johnemms
| posted on 2/11/11 at 02:12 PM |
Just a slight kick back on starting when hot..
starts and seems to tick over fine..
slight open of throttle - turn over - fires..
Strobe 650rpm - 0 degrees
connect vaccum - Strobe reads 12 degrees advance - 800rpm
I know what you mean - but if i set 12 degree static then conect the vaccum its way too much advance..
anyone else have any info?
cheers
BaileyPerformance
| posted on 2/11/11 at 02:19 PM |
cheers
Hello,
you would expect any engine to kick back at a static setting of tdc. what engine is it and has it been modifed?
Where is the vac signal coming from? off the manifold directly?
BaileyPerformance
| posted on 2/11/11 at 02:30 PM |
Hello again!
Sounds like you have the vac connected to the inlet manifold, this is incorrect, it would normally be connected to the carb - on a drilling next to
the throttle flap so the dizzy only sees vacuum at light throttle NOT at idle.
If you like call me 07967 222967 and i will explain what to do. Cheers Dale.
johnemms
| posted on 2/11/11 at 03:42 PM |
Cheers for the chat Dale..
All info taken on board.. vaccum now history..
Set static strobe at 12 degrees - runs fine - so far..
Will set maximum advance once i get a different strobe - not driving it yet ...
Just won a nice 'dial back' strobe on fleebay.. will be sorting the dizzy n timing out very soon !!! cheers Dale..
BaileyPerformance
| posted on 2/11/11 at 05:33 PM |
No problem John, nice talking to you.
Good luck with your project!
