Author: Subject: Head work in the Coventry area
mazie
posted on 4/11/11 at 11:26 AM Reply With Quote
Now the cars off the road for winter I'm looking at fitting some pipe 285 cams I have. Can anyone recommend an engine tuners to port , polish and flow bench my silvertop head?
Also has anyone had this work done and can give a rough price to budget for?
gregs
posted on 4/11/11 at 11:41 AM Reply With Quote
I used cylinder head developments in Bromsgrove for my Pinto, couldn't fault the service, but be warned it ain't a cheap process think mine was ~£700.
linky
[Edited on 4/11/11 by gregs]
Pdlewis
posted on 4/11/11 at 12:31 PM Reply With Quote
you could try Wilcox in Hinckley
Link
Build Photo Album
Updated 05/02/2009
mazie
posted on 4/11/11 at 12:50 PM Reply With Quote
£700 for a head port an polish?? My god if it's going to cost that much combined with the cam shafts , bottom end bolts and sundries the extra 25 or so horses isn't worth it.
Ive heard of chess mans Motorsport. Anyone heard of them?
PumaWestie
posted on 4/11/11 at 02:10 PM Reply With Quote
Chesman Engineering in Edgewick Road. Used them some time ago for X/Flow head.
ashg
posted on 4/11/11 at 02:39 PM Reply With Quote
geez £700 on a pinto.............. thats a new 2.0 zetec or one of may other second hand mental power engine choices
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Andy S
posted on 4/11/11 at 03:37 PM Reply With Quote
You could drop a mail to this chap -
http://www.royburrellengines.co.uk/
Roy is semi-retired but does take on the occasional bit of work - he does a lot of the specialised head works for the local Coventry tuners and likes to keep a low profile to keep his work load light.
You will not need much work on the silver top just throats and casting tidy up to match to those cams.
Andrew
PumaWestie
posted on 4/11/11 at 08:14 PM Reply With Quote
Yep - I know of Roy. He used to work at JE Developments - the Rover V8 specialists.
CNHSS1
posted on 4/11/11 at 08:41 PM Reply With Quote
Also worth looking at Autosprint nr Cov, Geoffs work is top notch, defo no BS!
Chesmans machine work is excellent
will121
posted on 4/11/11 at 08:53 PM Reply With Quote
a 16v is never going to be cheap and i accept a proven profesional flow bench job will be best but why not a DIY job, done mine with milder 270 newman cams for 173bhp. Also might need the tappet area 'relieving' a bit with 285cams to enable the extra lift to clear so may be worth taking the cams along to to check
[Edited on 4/11/11 by will121]
mazie
posted on 6/11/11 at 08:37 PM Reply With Quote
So the DIY job option: I've done a lot of fabrication work so very comfortable having a go but what equipment am I going to need ?
I don't have a compressor and now only a decent battery dill.
