mrwibble
| posted on 4/11/11 at 01:41 PM |
ID of st170 stub manifold
Anyone know the ID of the rubbers from an ST170 manifold? I have a set of gixxer 600 TBs with ED of 45mm trying to work out the best solution for
mounting them to a zetec e.
HowardB
| posted on 4/11/11 at 02:12 PM |
I can measure mine tonight, as I am doing the exact same thing,.. also to a zetec in a fury
Howard
mrwibble
| posted on 4/11/11 at 02:32 PM |
ooh excellent thanks!
wombat
| posted on 4/11/11 at 02:39 PM |
Drop me a u2u with e-mail address and will gladly forward info I gathered b4 buying my TBs
I have GSXR600s with newly arrived ST170 inlet manifold too and will be looking for same solution.
Flak Monkey can supply custom fuel rail or you can modify ST rail
stevebubs
| posted on 4/11/11 at 02:45 PM |
I used Fuel Filler Hose for my 750 bodies..
mrwibble
| posted on 4/11/11 at 06:33 PM |
thanks for replies, most helpful. Fastdan has offered me a manifold setup for gsxr750s, with spacings of 71-75-71 does anyone know what these spacings
mean?
HowardB
| posted on 4/11/11 at 09:00 PM |
I'll post a couple of pics of my TB's,
Tips picked up elsewhere in the forum, extended lugs (red) using a bit of steel angle, extended modular fuel rail by turning new aluminium slugs, and
new cable clamp from a handy nylon bolt,...
For the ST170 plastic inlets, the rubbers are very forgiving and will fasten with a jubilee clip to a range of sizes, but the inlet on the ST170 is
OVAL and is 54mm wide x 47mm tall, so similar to something about 2" round.
Guess the dims from fastdan are the spacings between the pipe ends O-71-O-75-O- etc three gaps for 4 inlets, for info the spacers added to the
Hayabusa ones are 10mm and 15mm to suit the ST170.
Hope that helps.
Howard
mrwibble
| posted on 4/11/11 at 09:23 PM |
yeah thanks, Howard, all very useful, still not 100% on the distance between pipe ends, might become clearer tomorrow when i get a chance to play with
the units.
I take it the ID of the rubbers isn't far enough from 45mm to cause concern?
Ed
[Edited on 4/11/11 by mrwibble]
HowardB
| posted on 4/11/11 at 09:31 PM |
when you dismantle them, watch out for the little spring that pings our and rolls under something, never to be seen again,....
Are you going to use MS?
Howard
mrwibble
| posted on 4/11/11 at 09:33 PM |
I have an omex 600 sat on the shelf gathering dust. just missed your reply with my edit, are your Tbs around 45mm ED?
cheers for the tip on the springs might do it in the living room when the misses is out.
Ed
HowardB
| posted on 4/11/11 at 09:36 PM |
mine are busa bodies, a bit bigger, so about 54mm or so, but I am sure that the rubbers from the ST170 will fit ok, I just popped them into some
boiling water to reshape them, after trimming the internal rib away,....
hth
Howard
