JohanP
| posted on 10/8/04 at 11:05 AM |
Size of Webers.
Can anyone tell me when I should use Weber 40 and when to use Weber 45? I'm planning to replace the original carburator on my 2 liter
Pinto-engine. The engine has only been cleaned up, painted and has had a new original camshaft fitted. Now I've been offered both a pair of used
40:s and a pair of used 45:s.
Are there any guidelines for when to use 40s and 45s?
/Johan
I have fun Seven days a week!
Finished: http://www.locostbuilders.co.uk/viewthread.php?tid=52344
Bob C
| posted on 10/8/04 at 11:09 AM |
It's size of main venturi that counts - if you have a choke per cylinder there's a weber chart that tells you venturi size vs cylinder
displacement & max power revs, I'll email you a copy if you want.
Bob
stressy
| posted on 10/8/04 at 11:11 AM |
If your going to go for big power latter, i.e. 150 bhp+ then probably best to go for 45, if not you can get the power out of the 40s. If you go 40 you
will probably get more low end torque. I used 40's when i had my pinto and they were fine.
