neilp1
| posted on 7/11/11 at 12:02 PM |
What Fuel Pump?
Can anyone recommend me a fuel pump from tank to swirl pot. I hadn't planned on using a swirl pot, but decided it may be a good idea to put one
in now instead of later!!
[Edited on 7/11/11 by neilp1]
turnipfarmer
| posted on 7/11/11 at 05:49 PM |
Mine's a simple Facet solid state job. Doubtless others will have different ideas! But it doesn't need to be anything fancy. Anything low
pressure (eg suitable for carbs) will be OK because it only needs to run at a few psi just to keep the swirl pot topped up. The main work is done by
the hp pump that comes after the swirl pot. Make sure you have a filter between the tank and the lp pump though.
| posted on 7/11/11 at 06:04 PM |
Discovery in tank one?
LAND ROVER DISCOVERY 1 V8 IN-TANK FUEL PUMP`93 ON | eBay
