carlknight1982
| posted on 29/11/11 at 03:05 PM |
Ford Tdci to RWD
Its not a question of why atm its more a question of how, anyone looked into it already?
Logic will get you from a A to B
Imagination will take you everywhere.
owelly
| posted on 29/11/11 at 03:17 PM |
Transit?
http://www.ppcmag.co.uk
carlknight1982
| posted on 29/11/11 at 03:41 PM |
i had thought about that but arent most of the new ones FWD
owelly
| posted on 29/11/11 at 03:50 PM |
IIRC you can get fwd, rwd or awd. And they fitted them to Freelanders so chances are you'll find something to do the job!
Dunno how much fun it will be when you try to get it to run as all the injection bits need coding.
amalyos
| posted on 29/11/11 at 04:56 PM |
Only the smaller transits are FWD. If you look at the 350, they are all RWDs.
http://stevembuild.blogspot.com
PSpirine
| posted on 29/11/11 at 06:35 PM |
Land Rover Defenders have the TDCi Puma engines.. 6 gears, just like a BEC. (not quite..) Not sure how you'd work around the transfer box
though. At least it means that there's a longitudinal sump/exhaust and inlet manifolds available!
What's the TDCi block based on?
