lewis
| posted on 29/11/11 at 09:43 PM |
Zetec remote oil filter
Can someone recommend to me where to buy a remote oil filter kit for a 2.0l blacktop zetec please,also when fitted do they use the standard zetec
filter or do they need specific filters? Cheers Lewis
I am a driving god!..........sort of
austin man
| posted on 29/11/11 at 10:16 PM |
why the remote filter ? is it to get around the steering issue
lewis
| posted on 29/11/11 at 10:49 PM |
Yes mate not enough clearence with a Renault 5 filter fitter so need to source a remote system.
austin man
| posted on 29/11/11 at 11:01 PM |
I modified the steering shaft and put another UJ in some pics in my archive I think
dlatch
| posted on 29/11/11 at 11:06 PM |
i am guessing that one
tbh i have same issue but the ren 5 filter fits on mine but i would still like a remote filter setup with room for a nice large standard filter
austin man
| posted on 29/11/11 at 11:45 PM |
Thats one of them thought I had put a couple in as I have done a couple now
plentywahalla
| posted on 30/11/11 at 12:00 AM |
mocal kit on ebay 59 quid. More benefits than just clearing your steering rack
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
lewis
| posted on 30/11/11 at 08:49 AM |
Must be eaiser to fit a remote filter kit than modify the steering rack though?
found this one on eBay but unsure if it will give me enough clearence still?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=400258592718&index=1&nav=SEARCH&nid=40598616184
r1_pete
| posted on 30/11/11 at 11:03 AM |
I got mine from think automotve, burton do them too.
Be carefull you get the filter head flowing the correct way for your installation, ask me how I know and had to send it back for the correct one....
Bizarro
| posted on 30/11/11 at 07:41 PM |
Bought sandwich plate and filter head from Rally Design and got pipes from Think Automotive. You can buy everything from Think Auto but Rally Design
are a little cheaper for the plate and head which is OK if you're ordering something else to combine the postage.
As r1-pete has said, think about where you are going mount it prior to ordering. You can get the inlets/outlets on right, left or top.
This is mine:
  remote filter
Gives plenty of clearance:
  remote filter2
lewis
| posted on 30/11/11 at 08:02 PM |
Thanks guys,bizarro do you have part numbers of what you ordered? There seem to be a lot of different thread sizes and left/right flow ect,looks like
I need the same as your install.
Bizarro
| posted on 30/11/11 at 08:58 PM |
From Rally design:
Remote filter head RFH3B
http://www.rallydesign.co.uk/product_info.php?cPath=340_525&products_id=14705
I already had the sandwich plate but I believe it is this (may be worth speaking to them before ordering to confirm):
http://www.rallydesign.co.uk/product_info.php?cPath=340_527&products_id=3381
Pipework from Think Automotive:
http://www.thinkauto.com/acatalog/On_line_shop_Push_on_hose___fittings_43.html
1 metre ½” push fit hose: FBN0800
2X ½” BSP X ½” NPTF nipple: MMS10-8-8
2 X ½” BSP straight: HEFP3-8
2 X ½” BSP 90: HEFP93-8
The oil filter is any Ford ¾”UNF, mine is for a Focus. I took the filter head to local motorfactors and screwed a filter on to check.
Hope this helps....
lewis
| posted on 30/11/11 at 09:38 PM |
Big big help mate thanks for taking the time
