femster87
| posted on 1/12/11 at 10:16 PM |
ford pressure regulator
Hi guys, I was wondering if I can use fuel regulator that came with the engine. If yes I have a few questions
I have a blacktop 2.0 zetec engine
what pressure is the regulator set at?
As I am not using the ford fuel rail, is there an adaptor I can use to connect the regulator to the line? A pointer would be good. Thanks
Myke 2463
| posted on 2/12/11 at 07:58 AM |
The one from my blacktop has 3.7bar stamped on it. if that helps.
Be Lucky Mike.
mrwibble
| posted on 2/12/11 at 10:57 AM |
really? i was under the impression the zetec ran at 3bar standard.
Myke 2463
| posted on 2/12/11 at 04:59 PM |
Just checked and no ford part numbers on it just 3.8 not 3.7, came with a st 170 manifold and injectors which are the correct ones.
Be Lucky Mike.
mrwibble
| posted on 2/12/11 at 06:11 PM |
i think that might be the question then, i think the standard 2.0 and 1.8 were 3 bar. pretty sure mine was @ 44psi which is 3 bar. which would be
fairly standard for any 16v efi of the zetec age if not up current.
plus what some people thought was a regulator on the st rail wasn't?
http://www.locostbuilders.co.uk/viewthread.php?tid=162982
[Edited on 2/12/11 by mrwibble]
