Author: Subject: Crossflow
Trollyjack
posted on 11/1/12 at 07:53 PM Reply With Quote
Crossflow
I'm rebuilding a 1300 cross flow
What the best for upgrading the Distribrtor
Currenty its a ford Type with points and a condensor
It looks in good nick have stripped it down and no wear is evident
It has a vacume advance and has weights in the base that also advances, all looks fine
wanting to go to electronic
what is the best for performance
thanks
TrollyJack
posted on 11/1/12 at 08:01 PM Reply With Quote
If you can find one a distributor frm a Valencia engined Escort is a popular conversion, get the small wiring loom , connectors and the coil. Just need 3wires connecting
flibble
posted on 11/1/12 at 08:02 PM Reply With Quote
Heard good things about pertronix when I was investigating the same for my 1690 xflow, although I bought one (and coil) I never did get to try it out as I swapped to a SAAB lump instead, the reviews were favourable though
[Edited on 11-1-12 by flibble]
trialsman
posted on 11/1/12 at 08:18 PM Reply With Quote
I have the Petronix on my 1300 and love it. I was used to doing the timing every few months and now I just do it for practice. It is always spot on!!! Russ
myke pocock
posted on 11/1/12 at 08:36 PM Reply With Quote
If you use the Valencie distributor, remove the small module from the side of the unit, clean the faces and then refit using heat conducting compound. I got some from an electronics service engineer. The faces have a habit of oxidising causing problems with preventing the transfer of heat from the module to the distributor body.
