killieaitken
| posted on 25/1/12 at 09:10 PM |
Weber 40's
Does anyone know the size of the jets to best use on a 1300 crossflow? I have lots of jets but not a clue! also i have this on my engine but dont know
if i need to connect this to anything or what it is exactly
tony.g
| posted on 25/1/12 at 09:18 PM |
I can't help with jet sizes but that's your fuel pump.
killieaitken
| posted on 25/1/12 at 09:24 PM |
No problem, so since i have installed a new fuel pump (high performance) i take it the factory fitted one is no longer needed?
Brian R
| posted on 25/1/12 at 10:55 PM |
Take the pump off and stick one of these on.
http://www.burtonpower.com/fp281.html
killieaitken
| posted on 25/1/12 at 11:59 PM |
cheers Brian, i take it this needs to be done to ensure good running?
[Edited on 25/1/12 by killieaitken]
Alan M
| posted on 26/1/12 at 09:40 AM |
It won't affect the running but is wasting engine power as you will still be operating the mechanical pump but just trying to pump fresh air!
MakeEverything
| posted on 27/1/12 at 07:05 PM |
It would be cheaper to leave it on. The drag on the engine from this pump is negligible as it is pushed by a cam on the camshaft (or crank, i forget
which now) not turned like a power steering pump.
Kindest Regards,
Richard.
killieaitken
| posted on 7/2/12 at 05:18 PM |
cheers i found a company that produced a blanking plate for £2.50 delivered! Was a 2 minute job
