Author: Subject: sierra / granada diffs
ajw
posted on 29/1/12 at 05:51 PM Reply With Quote
Will lobro shafts from a granada 7.5 in diff fit into a 7 in casing.Fitting new titan lsd and need to build up a 7in diff with lobro unit
minitici
posted on 29/1/12 at 08:08 PM Reply With Quote
They will fit but you will need 1/4" spacers on the push-in bits.
This could also give you problems with your driveshaft lengths if they are already tight (flange faces will be 1/4" further out on both sides).
ajw
posted on 30/1/12 at 08:14 PM Reply With Quote
sierra diff info
Thanks, I have contacted road and race transmissions in Kent and they will build up the diff for me and fit 4/4 to 1 c/p and titan limited slip diff
