nickw2000
posted on 31/1/12 at 11:57 AM |
fitting a car battery on BEC
are there any issues with fitting a normal size car battery on a BEC
my fireblade engine is run by the standard small battery but its killed easily with my electric reverse.
i fear it wont start the car up if i use the reverse
so something with bit more amps would work?
matt_gsxr
posted on 31/1/12 at 12:05 PM |
It will work fine with a big battery, just a shame to have to carry around the extra mass
roadrunner
posted on 31/1/12 at 12:53 PM |
Wouldn't fitting two bike battery's be lighter than a car battery.
posted on 31/1/12 at 12:58 PM |
Run the reverse motor off a separate battery with a split charge relay (or better an "intelligent" split charge relay) between
the two batteries.
You could also fit a master switch between the two batteries for emergency use
Tanya batteries is a reputable on line supplier of all types of battery. http://www.tayna.co.uk/
posted on 31/1/12 at 01:02 PM |
How about devising a small lever to raise the revs whilst you use the reverse motor? Ie prevent stalling. Or maybe make it reverse a bit slower to
reduce the effort.
loggyboy
posted on 31/1/12 at 02:01 PM |
Surely just running the reverse motor when the car is running is the answer?
mark chandler
posted on 31/1/12 at 02:04 PM |
The charging load that can be drawn a car battery will fry the regulator, if unlucky it will then move on and fry the generator windings.
NOT RECOMMENDED !
Regards Mark
40inches
posted on 31/1/12 at 02:49 PM |
NOT RECOMMENDED !
Regards Mark
Can this be confirmed
Plenty on here running a car battery with bike engine. I have gone the route suggested by BT.
Should I be worried?
roadrunner
posted on 31/1/12 at 03:11 PM |
I use to use a car battery before I fitted a BEC battery and I had no issues. From memory, the car battery was in for more than a year.
Brad.
mark chandler
posted on 31/1/12 at 03:50 PM |
893 - 919 Fireblade engines are particularly weak in this respect, I have fried more than one regulator as the car is left standing for a long time
between runs, same again when I ran one as a road bike.
russbost
posted on 31/1/12 at 04:05 PM |
I've always used an 063 car battery with the ZZR1400 engine in the Furores, never had any charging issues.
andyfiggy2002
posted on 31/1/12 at 05:43 PM |
my 2004 megablade kit supplied by the factory came standard with a car battery i assume because it drew more current with a fuel pump, extra lights
etc & the bike having such a fragile reg/ rectifier, i didn't fancy hauling all that lead around i switched back to the a bike battery &
an uprated reg/rect
[Edited on 1/2/12 by andyfiggy2002]
Proby
posted on 31/1/12 at 06:30 PM |
My 2001 MegaBlade Kit (Full Kit Form inc battery) came with a bike battery? So unless they changed things.
Just get out and push, good exercise!
40inches
posted on 31/1/12 at 06:47 PM |
I would think that charging a flat car battery may stress the charging circuit, mine is always on a maintenance charge so
the engine would only have to keep the batteries topped up. Possibly.
nickw2000
posted on 8/2/12 at 09:19 AM |
People with the same problem as me, with the electric reverse killing the battery, what battery do you have? How many AH? And does it work?
40inches
posted on 8/2/12 at 09:49 AM |
I fitted the smallest 330cca battery I could find. Drives the car over a 2x2 easily, not on the road yet, but don't foresee a problem.
Mega Fuse (now 250amp)
nickw2000
posted on 7/3/12 at 07:23 PM |
what battery from odessey is recomended please? for starting the engine with no loss of battery power after using elec reverse?
Custardpants
posted on 7/3/12 at 08:14 PM |
My MK came with a car battery but looking at getting something smaller as my electric reverse has been taken off....
andyfiggy2002
posted on 4/4/12 at 02:59 AM |
westfield specify a car battery for their BEC,s
link
Johneturbo
posted on 4/4/12 at 07:24 AM |
Apart from having an extra tail light, i don't see why you'd need a car battery, apart from having a reverse/heater/wipers/radio
adithorp
posted on 4/4/12 at 07:38 AM |
I've got a Powervamp PV15 (now PVR15 I think). Same sort of output as a 063 but half the size and weight. Been on 4 years now and never let me
down. Stands for relativly long periods over winter, is never disconnected with the immobiliser LED going and never fails to fly over. I don't
have reverse though but just do what most of us do and avoid reverse situations. They do a nice ally battery carrier as well.
As said running a BEC with a flat battery can fry the charging circuits but using the altermator to charge a discharged battery can do that on any
car. They aren't designed to charge flat batteries. Avoid it if at all possible whether its on a BEC a CEKit or a tin-top.
http://jpsc.org.uk/forum/
