Author: Subject: Engine Configuration
Dave Bailey
posted on 5/2/12 at 08:51 PM Reply With Quote
For those of you experts out there....
I have problems setting up my ST170 engine... Emissions are high....
The engine has been dry sumped and I have removed the crankcase vent system and blanked off the hole with a plate.... The cambox vent oes directly to the oil catch tank....
Is this a good idea or do you think I should vent the crankcase.....
Dave B
Ben_Copeland
posted on 5/2/12 at 08:54 PM Reply With Quote
Original injection? Carbs? Throttle Bodies? Lambda sensor installed? Wide band Lambda?
Ben
Locost Map on Google Maps
Enter Your Details Here
big_wasa
posted on 5/2/12 at 08:57 PM Reply With Quote
loads of zetecs run with just the one breather and they breath fine.
[Edited on 5/2/12 by big_wasa]
Dave Bailey
posted on 5/2/12 at 09:55 PM Reply With Quote
The engine is as follows....
1. Jenvey throttle bodies. 48's (a bit big but they were free!) 60mm trumpets.... Airbox with single input.
2. 4-1 Exhaust with a sports Cat
3. S60 DTA ECU
4. Innovate wide band Lambda sensor
5. Crank Sensor
6. Variable inlet Cam
7. Cam Sensor
8. Air temp Sensor
9. TPS
10. 3 bar fuel reg
thanks
Dave B
rdodger
posted on 5/2/12 at 10:36 PM Reply With Quote
How high?
Is the cat new, did it get properly hot?
Has the ECU been mapped properly on a rolling road?
Dave Bailey
posted on 5/2/12 at 11:00 PM Reply With Quote
Pretty bad....
CO = 0.09%
HC = 851ppm
CO2 Level = 9.7%
O2 Level = 7.66%
Lambda = 1.47
Yes the Cat is new.....
I have enabled the close loop control today after DTA gave me a few setting updates... But it still miss fires a bit...
I will get it back on the Analyser when the weather gets better....
Dave B...
Dusty
posted on 6/2/12 at 01:14 AM Reply With Quote
I have a 50,000 mile ST zetec and it breathes pretty heavy. Much more than the prior silvertop and blacktop I had in before. Another ST zetec user also said his engine was a heavy breather. I have both block and cam cover vented to a catch tank. Even so the car disgraced itself at the last rolling road session with an oil spill, blown out of the catch tank at high revs full load. So I would vent the block and fit a well designed oil trapping catchtank.
