Author: Subject: Pinto to duratec what's needed
carlknight1982
posted on 26/2/12 at 07:13 PM Reply With Quote
Starting to get my shopping list together for my duratec conversion having been talked out of using. V8.
So I have (will be getting) a 2001 mondeo duratec
Away do I need to removed with the engine, ie standar induction ecu wiring etc etc
I already know I'm going to need a bell housing for the type 9 along with a st150 or aftermarket flywheel and a sump.
I've read that the pinto exhaust can be reused with a new flange.
I'm currently running 40 dcoes and mega jolt I'm guessing I'm going to have to change to mega squirt and throttle bodies do will prob need to fit a return line and swirl pot prob need to change to a hi pressure pump? I'm currently running a facet Reston and filter king.
So assuming I go mega squirt what throttle bodes ? Gsxr 750/1000 k1's? And a fast dan manifold.
I'm hoping someone can help with the list. This is going into my Haynes roadster.
[Edited on 26/2/12 by carlknight1982]
Logic will get you from a A to B
Imagination will take you everywhere.
bob
posted on 26/2/12 at 07:38 PM Reply With Quote
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=109801
Tiger Super Six
posted on 26/2/12 at 07:41 PM Reply With Quote
Assuming your car has already passed IVA/SVA then you can continue on carbs. I converted from Pinto and ran mine on 45's but they do need 5 progression holes in them. Save the return to the tank extra fuel system costs.
Mark
Tiger Avon
big-vee-twin
posted on 26/2/12 at 09:53 PM Reply With Quote
See this thread may also helpful link to thread
Also make sure your bellhousing has a bolt in the position shown if not fit one it will stop your gearbox layshaft falling out
[img] Layshaft retaining bolt
[/img]
[Edited on 26/2/12 by big-vee-twin]
http://www.triangleltd.com
