FuryRebuild
| posted on 3/3/12 at 08:35 AM |
Duratec - decoking advice
Morning Collective
I've got all the grubbins off my new (to me) engine and looking into the exhaust ports, there's lots of carbon in there.
What's your advice for decoking it? I am thinking of trying the parts washer, and if that doesn't work, maybe something like carb cleaner
solvent.
Any ideas?
Mark
me!
| posted on 3/3/12 at 08:48 AM |
Mr Muscle oven cleaner sorted my zetec pistons/head out a treat!
dave r
| posted on 3/3/12 at 11:10 AM |
where i used to work, we used to use a non gritty hand cleaner soap
used to paint/soak it overnight and the carbon used to just wash off
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
mark chandler
| posted on 3/3/12 at 01:41 PM |
Drain cleaner for me
DIY Si
| posted on 3/3/12 at 01:44 PM |
Unless there's enough to block the ports up, and if there is the engines FUBAR'd anyway, why bother? The first time you run the engine
it'll go black again. Fair enough if you really want to and have not much else on, but I wouldn't bother.
Sun Tzu, The Art of War
FuryRebuild
| posted on 3/3/12 at 02:36 PM |
Interesting point, Si. I thought the carbon built up over time.
I thought a cleaner head meant more power. If I decide to put new cams in then i'll decoke it.
pjay
| posted on 3/3/12 at 07:49 PM |
Nitromors paint stripper - done quite a few heads now and it's good stuff (but nasty stuff - if you see what I mean).
Guess you're looking to do it with the head on - if so how do you plan to stop any crap getting into the cylinders? Not tried it but I guess you
could turn the engine upside down...
FuryRebuild
| posted on 3/3/12 at 09:06 PM |
hi pjay
I'm going to compression test it first, and then probably get the head off. My reasons are:
1) I think I'm going for stage 1 cams. With my jenveys and really free flowing exhaust, i should see 200 with the right management
2) The engine came from a scrapper with all the warranty that entails. I was assured it was a good one, but I will see when I test the compression.
The front idler pulley has a knackered bearing so there may be wear in other places
3) i intend to run it on track days and fast road, so with sustained mullering, it may be prudent to change the cam chain.
I have a parts washer, so I'll be interested to see if a stint in it overnight does any good. If not, a day soaking in nitromors before going
back into the parts washer will be the way.
So, to eliptically come to the point, i shouldn't end up flushing crap into the bores
Thanks for the tip
Mark
DIY Si
| posted on 3/3/12 at 10:33 PM |
Whilst it does build up, the layer is going to be tiny. The cleanliness of the exhaust will make no difference to power, but if you're taking
the head off, a light going off to smooth the ports out won't hurt any. The inlet however, should be fairly clean, but only because anything
else points to problems!
pjay
| posted on 4/3/12 at 08:56 AM |
Hi Mark - Sounds a good idea to get it running and do the CT first. As DIY Si says unless there's loads of build up its not a problem.
If and when you do take the head off you might consider lapping the valves in as well (the need depends on mileage - 16 valves and exhausts are the
worst to lap in...).
Do you find you decide to one thing and it spirals into 101 other jobs...
Later if you do decide to replace the timing chain (know the thoughts and did mine on my first engine) you'll need to take the crank pulley off
to get the timing chain cover off (reference to one of your other threads IIRC).
perksy
| posted on 4/3/12 at 11:15 AM |
Used Fairy power spray and Mister muscle oven cleaner on the last one i did and it came up really well
(make sure its all washed off afterwards)
The Mrs said it was a shame i didn't pay as much attention to doing the washing up...
FuryRebuild
| posted on 8/3/12 at 02:00 PM |
Persky
It's all off now, and the front cover has sat in the parts washer for a day to shift the top level grime.
I polished my cam cover with a nylon cup brush, which made it shiny and smooth, but there are a few pittted marks in there.
I think I may try some oven cleaner next - soak it in that for a while and then back in the parts washer - may make it nice and shiny.
I'm still doing other parts of the strip, but i reward myself with a clean and polish when i've done another good job (like getting the
bloody front pulley off).
batteredoldsupersport
| posted on 8/3/12 at 03:32 PM |
One favourite for cleaning things up is a bucket of diesel overnight. It shifts most things. As ever, take the usual precautions in handling and
don't bathe in the stuff.
FuryRebuild
| posted on 8/3/12 at 05:03 PM |
Just spoken to my father-in-law (retired chemistry teacher) and he recons drain-cleaner - it's a alkali and will get the crap in the pits of the
cast out of the way and give me a shiny surface without having to go mad with the nylon brush to polish it.
we shall see - off to B&Q for drain cleaner.
pjay
| posted on 8/3/12 at 06:32 PM |
Sounds good - post some pics to show the results.
| posted on 8/3/12 at 06:38 PM |
Just watch the drain cleaner on ally. If it forms gas bubbles these are hydrogen gas and it's formed by the caustic solution attacking the ally.
You don't want this, it will leave pits if given long enough.
pjay
| posted on 8/3/12 at 06:42 PM |
All aluminium engine so now doesn't sound quite so good. Does it just depend how long it's left on there?
| posted on 8/3/12 at 09:04 PM |
It does depend and also on the chemistry of the solution. You need to read the bumf, if it says keep it off ally then keep it off ally. Some caustics
are passivated with silicates etc that are not corrosive to ally. some are evil bastards and should be kept off. The snag is that they act over time
on carbon and lacquer, they also act over time on ally. You can tell though, make a solution and chuck the part in. If it starts to produce bubbles of
gas, get it out and wash the caustic off. It won't do any harm over a few minutes IF you wash it off properly.
FuryRebuild
| posted on 8/3/12 at 11:24 PM |
It was all rather ignominious.
The sink cleaner just turned the surface black, no problem - nylon brush polished it out.
Kitchen surface cleaner got through the grime but couldn't get the tiny pitted marks out.
t-cut did some work (on a polishing disk on a dremmel) but not brilliant.
auto-glym wheel cleaner made a strong smell, then turned the surface black. polished it out.
then i thought: "buggrit" and put it in the blasting cabinet. All the little crevices are now nice and clean. Then i polished it with the
cup brush.
Can you spot the deliberate mistake?
The back of the cam cover still have oil residue on it, so there is blasting grit stuck to it. hey-ho.
I've taken the baffle plate out, and am now running it again in the parts washer overnight on the underside to get most of the crap off, before
cleaning by hand and inspecting VERY CAREFULLY before putting it on the engine.
Still, we live and learn.
aquablastcenter
| posted on 3/7/12 at 11:11 PM |
Aqua & Soda blasting for engine / gearbox
There are two safe and easy ways to clean / restore engine and gearbox parts.
1. Aqua Blasting with silicon bead
This will remove road dirt, corrosion and most staining from alloy.
All parts must have bearings, seals and moving parts removed.
Parts need degreasing and paint removing before blasting
2. Soda Blasting
A dry blast process that is ideal for removing oil deposits, paint and general road dirt
Parts can be cleaned without the need to dismantle, so from cylinder heads to
complete engines can be cleaned and prepared for painting.
Details can be found at http://www.aquablastcenter.com
FuryRebuild
| posted on 4/7/12 at 07:28 AM |
Dear Aquablastcentre
I've noticed you have brought multiple old threads to the surface in order to sell your services. I think noone here would really mind about
that, but Chris (owner of the board) has some kind of registered trader policy.
I suggest you contact him and see what the policy is.
www.furyrebuild.co.uk
aquablastcenter
| posted on 4/7/12 at 09:12 AM |
Will do and hopefully i can sort a discount out for members of the site
b14wrc
| posted on 5/7/12 at 11:33 AM |
I'd stick it in the dish washer after you have used the drain cleaner, I have installed one in the garage for car parts and it works a treat!
Rob
20vt powered rear engined locost
FuryRebuild
| posted on 5/7/12 at 11:50 AM |
I need to know if I could have it anodised as well. I know I'd need to protect the liners but I do wonder if the anodising process would cause
harm or not.
