ali f27
| posted on 12/3/12 at 10:32 AM |
duratec flywheel
Hi I bought some parts of grassracer bellhousing flywheel etc they were new and unused for duratec to type 9 the flywheel has 10 mm bolt holes in it
duratec crank 12 mm they are from rwd motorsport and we think they maby sent pinto fly wheel the flywheel fits and the ring gear is correct for the
starter i can drill the flywheel to 12 mm but just wanted to know if anybody had any ideas
Cheers Ali
Tiger Super Six
| posted on 12/3/12 at 12:15 PM |
The RWD flywheel is designed to run with a pinto clutch, if that's what you're asking, unlike most of the others.
Mark
Tiger Avon
ali f27
| posted on 12/3/12 at 12:34 PM |
Hi Mark yea bought kit third party not direct was bouhgt originally from rwd from member on hear and never used prob is crank bolt holes are 10 mm on
flyweel and 12 mm on duratec crank
Tiger Super Six
| posted on 12/3/12 at 02:40 PM |
That does sound wrong then as my flywheel bolts just went straight through and bolted to the end of the crank. Maybe contact Ian and see if there is
anything he can do. Maybe they sent the wrong one out (for a different engine) by mistake.
Although you didn't buy it, he might help you out (or could the original purchaser sort it on your behalf?).
Mark
Tiger Avon
FASTdan
| posted on 12/3/12 at 03:36 PM |
Yeah likewise, our RWD flywheel fitted straight on with no mods so sounds like somethings not right.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
ali f27
| posted on 12/3/12 at 07:15 PM |
Chap from rwd emailed me going to ring me been on holiday
Ali
