AntonUK
| posted on 24/3/12 at 05:30 PM |
GSXR Throttle Body Air Filter Photos?
Could you be so kind in posting pictures of how re-spaced GSXR throttle body's filter have been mounted.
I would like to use a pipercross sausage filter with some kind of trumpet arrangement.
I'm currently debating in my head how to do it, as there does not seem a straight forward place to mount the back plate or trumpets on the TB I
have.
Any hints tip or photos etc welcome...
*Edit Photos added
[Edited on 24/3/12 by AntonUK]
Build Photos Here
redeye
| posted on 24/3/12 at 05:43 PM |
FastDAN's your man for fittting to the engine.....via a manifold...which he can also supply
Drop him a line
doddy
| posted on 24/3/12 at 05:56 PM |
you need the gsxr airbox trumpets as the help to fit the backplate
https://www.ebay.co.uk/str/4x4wheels
monck
| posted on 24/3/12 at 06:03 PM |
Hi i have some gsxr tb's on my car
I re-spaced mine onto a st170 manifold using st170 fuel rail and injectors Cost me around £55
I have 4 trumpets of a Gsxr i just bought an air box cheap of ebay £15 posted removed the trumpets and binned the air box there rubber not metal but
for the price difference i couldn't care
The trumpets have 2 claps holding on the 4 trumpets these still work despite being re-spaced
I have a blank base-plate to fit a piper-cross filter got it of someone on here its real good quality for around half the price and all i have to do
is cut holes for my tb's and fix it to them somehow ...
If you want some pics of my trumpets let me know i am going to have a go at fitting my back plate tonight
Ryan
monck
| posted on 24/3/12 at 06:04 PM |
Doddy... Just noticed your comment if i cut holes in my blank base-plate will the gsxr trumpets be enough to secure the plate ?
doddy
| posted on 24/3/12 at 06:14 PM |
yes thats right
doddy
| posted on 24/3/12 at 06:17 PM |
have a look on this tread you will see the airbox part
http://www.sportingfords.com/forums/viewtopic.php?f=16&t=1960
[Edited on 24/3/12 by doddy]
monck
| posted on 24/3/12 at 07:16 PM |
cheers mate ill get my plate fitted tonight ..(Not that i have a filter yet there not cheap !!!!)
| posted on 24/3/12 at 07:25 PM |
The rubber trumpets on mine had a section with a groove in where they fit in the original airbox.. I cut the holes in the back plate to suit and bobs
your uncle..
monck
| posted on 24/3/12 at 08:21 PM |
Coozer - Thanks for that exactly what i was looking for ...
Ill go out and do mine now
AntonUK
| posted on 24/3/12 at 10:48 PM |
Thanks all I will try an source a set of rubber trumpets then
[Edited on 25/3/12 by AntonUK]
Build Photos Here
