lsdweb
| posted on 28/3/12 at 03:21 PM |
K Series Throttle Bodies
Hi All
I have a set of bike throttle bodies and a K Series with plastic inlet manifold.
The inlet manifold nearest the head looks like the runners are straight and round. Does anybody know if anybody has successfully cut / machined this
to take bike throttle bodies?
Ta in advance
Wyn
lsdweb
| posted on 28/3/12 at 03:37 PM |
I also have an alloy inlet manifold (on a BRM engine) which looks similar although the intake runners look much bigger (about the same bore as the
TBs)!
[Edited on 28/3/12 by lsdweb]
| posted on 29/3/12 at 08:35 AM |
If you want to go this route I'd suggest finding an alloy VVC manifold (this was my plan when I was considering a K series a while back). Even
if you can't mate the TB's directly to the manifold runners, you could get some suitable stubs welded to them.
ROVER MGF 1.8 VVC INLET MANIFOLD ROVER K SERIES | eBay
lsdweb
| posted on 29/3/12 at 08:56 AM |
Thanks Mike
I've got an alloy one on a BRM (VVC) engine - not sure if the manifold can be welded (cast?), but I'm going to pull it off today and have
a look.
Ta
Wyn
| posted on 29/3/12 at 09:01 AM |
Oops, missed the bit about the BRM manifold, that's certainly the one I would be looking at using.
There is usually no problem with cast alloy components being welded, thing get difficult when you have to weld cast iron.
In fact it's possible to "weld" alloy using special low temperature alloy rods and a decent blow lamp, though a bit of practice is
needed.
[Edited on 29/3/12 by MikeRJ]
lsdweb
| posted on 29/3/12 at 10:43 AM |
Cheers Mike
I have used aluminium 'welding' rods in the past but don't think I have the skills to do the manifold - I'll pull it off
later and start measuring it!
CNHSS1
| posted on 29/3/12 at 03:21 PM |
cast manifolds manifolds often have a clear layer coating, anodising or similar that impedes welding. Give the area around the weld area a thorough
grinding to get to virgin ally before commencing
lsdweb
| posted on 29/3/12 at 04:45 PM |
My friend had a look at this afternoon and he can do it! :-)
