mad4x4
| posted on 18/4/12 at 12:02 PM |
High Idle
Would an Air leak cause my engine to idel at 1000 - 1600 regardless of settings in Megasquirt.... Just can get idle down low without cutting fuel to
the point of NONE!.
Scot's do it better in Kilts.
SeaBass
| posted on 18/4/12 at 12:11 PM |
Probably.
If it's on Bike TBs make sure you've blocked the little vacuum takeoffs etc & check the vacuum lines to the fuel pressure regulator.
coyoteboy
| posted on 18/4/12 at 12:15 PM |
Yup, any air leak into the manifold will cause high idle and leaning it out will do nothing but lean it out towards misfire.
