ditchlewis
| posted on 24/4/12 at 07:33 AM |
Type 9 breathing
One for all the Type 9 experts.
does the Type 9 gearbox have a breather to release pressure? if so where is it located?
the problem i have (and it was suggested by Bro in law a ferrari mechanic) is that the oil leaks i have are because the box is becomming over
pressured. i have noted that most uprated boxes have a breather put into the top plate.
Looking at the haynes book i cannot see anywhere the mention of a breather valve, so question if there is one to get blocked.
would it help if i put a breather outlet in the top cover?
ditch
SeaBass
| posted on 24/4/12 at 08:03 AM |
There is a small hole as a breather in the top cover. It sits on a small spherical protrusion and as some kind of shield underneath ISTR.
It often get painted over when the box is tarted up and people forget to unblock it.
Bluemoon
| posted on 24/4/12 at 08:54 AM |
^^ ditto also mine was full of crud (oil+dirt) easy to clean up..
mcerd1
| posted on 24/4/12 at 09:29 AM |
^^ what they said
also make sure the box isn't over filled - I think the level on some of the boxes is actually bellow the plug....
ditchlewis
| posted on 24/4/12 at 11:56 AM |
many thanks lads, just hoping that this will cure the oil leaks as it has coated the trans tunnel and leaks out into the footwells.
once again many thanks.
ditch
