redeye
| posted on 25/4/12 at 08:59 AM |
Duratec oil
Hi all
Another question for the guys fitting/fitted a duratec to their cars
I have the raceline oil filter adapter, and am looking to fit an oil pressure sensor with 1/8 npt thread
The raceline adapter doesnt seem to have the same thread as the original pressure switch either.
What have other done to fit a pressure switch and sensor to their Duratecs?
Patrick
neilp1
| posted on 25/4/12 at 10:05 AM |
I used an adaptor M12 to 1/8" IIRC which I purchased from ETB along with the digidash.
redeye
| posted on 25/4/12 at 10:10 AM |
Thanks Neilp1
Did you bother fitting a oil sender to control the light on the dash or did you just go with the oil pressure gauge?
big-vee-twin
| posted on 25/4/12 at 11:03 AM |
The thread is 12mm x 1.5, I bought a pressure switch for a Lotus Elise which had a higher pressure switching point to give earlier warning and an
adapter.
http://www.triangleltd.com
redeye
| posted on 25/4/12 at 11:14 AM |
I bought a pressure switch for a Lotus Elise which had a higher pressure switching point to give earlier warning and an adapter.
Was is this one like this you fitted?
LOTUS ELISE S1 111S VVC/MGF 1.8 VVC OIL PRESSURE SWITCH | eBay
Do you know what pressure the switch operates at as Ive read that the duratec has a low idle pressure....Obviously wouldnt want the light to be on
when the engine is idling
Many thanks for your help
Patrick
redeye
| posted on 25/4/12 at 11:19 AM |
im also considering one of these
oil light switch
given the option of 15psi and 25psi
which should i go for?
big-vee-twin
| posted on 25/4/12 at 11:41 AM |
A standard one is rated at around 5-7 psi, the Elise one I have is rated at around 20psi if I remember correctly and does extinguish the light when
ticking over.
Trying to find the details of the switch now.
big-vee-twin
| posted on 25/4/12 at 11:46 AM |
The operating pressure of mine is 13PSI but I cant find where I got it from, that 15PSI one would do the same job.
redeye
| posted on 25/4/12 at 12:03 PM |
Thanks very much for the help
Think Ive sourced all the parts ill need now
