myke pocock
| posted on 28/4/12 at 11:29 AM |
1300 x flow, DGAV and Valencia dizzy
A question for anyone who has a 1300 x flow with a DGAV and Valencia distributor. When i have the dizzy fitted I cannot twist it far enough anto
clockwise before the vac advance retard unit on the side hits the inlet manifold. i cannot turn the whole unit by 90 degress to try and get over that
as the multi connector on the body side appears to get in the way of the manifold. Can I grind the inlet manifold away a bit to allow the dizzy to
turn a bit more or run without the vac adv/retard? Anyone had this problem?
gazza285
| posted on 28/4/12 at 02:31 PM |
Remove dizzy, turn shaft a bit, then refit.
SeaBass
| posted on 28/4/12 at 07:09 PM |
Yep it should be easy to set it up at whatever angle by pulling out the dizzy and rotating. You'll only be limited by the spacing of the helical
teeth on the drive gear as far as I remember.
I ran exactly that setup when I first built my locost back in 2002 (yikes 10 years ago!). I had no issues with the distributor except trying the very
first start with leads 180degrees out.
JC
myke pocock
| posted on 28/4/12 at 07:41 PM |
Ah yes, the 180 out fiasco. Got some cracking flames out of the exhaust. Thanks for the replies. Done it and it works!!! Should have had the nouse to
do it myself but had a DOOHHHH moment.
