Author: Subject: running hot ...fuel issue ?
Valtra
posted on 6/5/12 at 10:57 PM Reply With Quote
My beleaguered Twink was running hot as well as low pressured (oil ) both to and from Stoneleigh today . Am I correct in thinking lean fuelling could make an engine run hot . It wasn't a scorcher of a day. Car didn't break down or boil over it just ran too close to the danger paint . Maybe I was just more vigilant than usual because I was watching the oil pressure . Seemed to improve when I filled up with Shell on the way home or is my imagination running overtime
"If it looks like it works and it feels like it works, then it works"
Valtra
posted on 6/5/12 at 11:00 PM Reply With Quote
by the way I have a continuing issue with running on 3 cyls under some steady running conditions ...... Going to Megasqurt soon so hope to cure that (and the low oil pressure at the same time)
cheers
snapper
posted on 7/5/12 at 05:20 AM Reply With Quote
Lean duel and/or under advanced ignition.
Oil pressure could be blocked pickup, worn pump, if not its the mains.
I eat to survive
I drink to forget
Valtra
posted on 7/5/12 at 03:04 PM Reply With Quote
