ali f27
| posted on 22/6/12 at 01:13 PM |
duratec fuel rail fitting
Hi have just got my fiesta st fuel rail how do i work a fuel return on it and i could do with some injector retaining clips wheres the best place to
get them
Cheers Ali
big-vee-twin
| posted on 22/6/12 at 01:31 PM |
The only way I could see was to remove the damper from the middle of the rail, take out its guts (carefully cos there's a sping in there) and
replace it this gives you a return, but its a tiny connection.
I then replacd the damper with a alluminium blank with a 90 degree pipe connection in it, but wasn't happy as it leaked.
So in the end I got a nice stainless steel open ended replacement from AT power, cost a lot, but I am know safe in the knowlege I will not have any
leaks from a bogde done by me.
http://www.triangleltd.com
ali f27
| posted on 22/6/12 at 04:06 PM |
Hi st fuel rail has no damper just 1 fuel connection so going to have to do some enginerring somewhere i am down in york at weekend might come over
for a look at your car
Cheers Ali
Nitrogeno25
| posted on 22/6/12 at 08:19 PM |
Cheers Ali
I modified mine with a return line. I will post a picture tonight.
Nitrogeno25
| posted on 24/6/12 at 05:25 PM |
get them
Cheers Ali
Here it is. I bought the fittings from ebay (stainless) and brazed them:
Hope this helps!
