wombat
| posted on 27/6/12 at 08:06 AM |
Zetec Flywheel - Advice please
Morning,
I have a 2.0 Silvertop needing a flywheel.
I believe from my research on here that this will do - Ford Focus MK1 Flywheel (1.8 Zetec) 98-05
Agreed?
Then I will need the Finis bearing + Ct133 Release + 2.0 Mondeo Clutch
Agree?
I love payday............
Bill
big_wasa
| posted on 27/6/12 at 10:08 AM |
Not the 2.0 clutch as that should be 240mm You will want the 1.8 clutch (220mm) from a car that had an mtx 75 gearbox so that it has the 1" 23
spline centre.
The rest looks good if going to a type 9 but there are more than one ways to do what you want.
Dont forget the spigot bearing for the end of the crank.
wombat
| posted on 27/6/12 at 10:43 AM |
OK, 1.8 Flywheel + 1.8 Clutch = Common Sense.
Yes going on a Type 9
Other suggestions on doing this Wasa then ??? "but there are more than one ways to do what you want"
Just planning on getting on the road with this set up, power upgrades etc much later, but seemed way to go for a bit of cheap lightness as got to buy
flywheel anyway.
Get this sorted then its propshaft + engine and gearbox mounts and I can offer the lump in, whoop !
ChrisL
| posted on 27/6/12 at 11:32 AM |
I think you'll need shorter flywheel bolts, more info here: http://www.zetec-cat.co.uk/
mcerd1
| posted on 27/6/12 at 11:39 AM |
as I understand it part of the problem with getting the right clutch is that the std. 1.8 focus uses the IB5 gearbox which has a 20mm x 17 spline
inputshaft with a 220mm clutch
type 9 boxes have 1" x 23 spline input shafts, the same as the MTX75 boxes used on the 2.0 focus, but that uses the 240mm clutch.....
the 2.0 pinto clutch is 215mm to suit a 1" x 23 spline
I have to say that I've never fitted a zetec to a type9, but I did take a few measurments of my type 9's and my tin-top (1.8 focus) when I
had its clutch out anyway
[Edited on 27/6/2012 by mcerd1]
me!
| posted on 27/6/12 at 12:04 PM |
As big wasa said, Mk1 Mondeo 1.8 (petrol) clutch is 220mm with the correct splines. Focus 1.8 Flywheel will be fine, you don't need special
bolts, although new ones might be sensible?! CCT133 is the correct release bearing, but I ended up with a LUK item that measures the same so hopefully
it will work. Top tip for the spigot bearing- don't hammer it in too far! Stop when the end face is level with the inside chamfer in the end of
the crank.
Well, that was my shopping list for a blacktop anyway, but it's not running yet!
big_wasa
| posted on 27/6/12 at 03:51 PM |
From memory you only need the shorter bolts with a modified fly' or a cvh fly' 2.0 + 1.8 should be the same bolts If you want shorter then
the auto has them.
wombat
| posted on 5/7/12 at 03:48 PM |
Afternoon,
Picked up a 1.8 flywheel for 32quid
2pc LUK Clutch for 57 - www.carparts4less - free next day delivery - well packaged - and fits!
Thx whoever posted link to them recently.
Made 1mm ali sandwich plate for filling gaps between engine n bellhousing.
Waiting for new f/wheel bolts to come.....
New plugs and rocker cover fitted + coil pack and thermostat (yes Wasa i still will need the connectors for this....)
Camping this weekend so no work in the garage :-(
Once I get this end sorted I will be asking for advice on timing end.
How to get pulley off for a start!
wombat
| posted on 10/7/12 at 07:57 AM |
Bolts
Ok, needed to make a few adjustments to my dust plate then fitted the spigot bearing (to just inside chamfer edge -thx Merc)
Put the flywheel on (1.8 Focus fits great - thx Wasa), then started fitting the bolts, well it was 10 at night and suddenly I thought "ah do
these need washers?''
Tried to convince myself to torque them up, but late night paranoia(spellcheck) set in......
At work for 0515hrs this morning so no chance to check.
So, no washers ?????
wombat
| posted on 10/7/12 at 12:16 PM |
Oh, and which way round does the clutch plate go??
Dumb day..
wombat
| posted on 14/7/12 at 01:07 PM |
Sorted
Thanks everyone, engine and gearbox now connected.
1.8 focus flywheel - eBay
1.8 mondeo 2pc clutch - carparts4less.co.uk
Spigot bearing - brt bearings ltd
Clutch release bearing - brt bearings ltd
Sandwich plate - me
Clutch alignment tool - Matt @ J M Lane Engineering Wisbech
Sump - Chopped by me, plates by me, welded by Ian Fowler @ Flash Customs (excellent job done)
So next on the shopping list is a starter motor, found one local off a 1.8 Sierra diesel , will this fit ? (how quick wil Wasa be this time?)
big_wasa
| posted on 14/7/12 at 02:44 PM |
lol no the diesel wont fit.
Its the 1.8cvh the dohc or a pinto with a spacer. In true ford parts bin stylee there is more than one type of motor that will fit the donor but not
your kit lol.
You ar elooking for a narrow body starter. Somthing like a lucas lrs707 from memory.
[Edited on 14/7/12 by big_wasa]
