Author: Subject: Lack of opening / closing ramps on 'performance' cam?
Nickp
posted on 23/7/12 at 07:48 AM Reply With Quote
Any camshaft experts in here?
I've picked up a set of reground cams for my Monte for a fraction of the £600 or so that a set of steel billet ones would cost me. I've used a dial gauge to plot them against a std cam. They don't seem too radical with only a smidge more duration and the lift is at least 10% higher right across its range with 16% greater area under the curve, which I think should work nicely. The big difference I did notice though was that the std cam had about 40deg opening/closing ramps compared to virtually nothing on the reground cam. I presume this is going to give the valve train a harder time, but how critical is it for the small mileage that I seem to manage in it these days?
http://www.guy-croft.com/download/file.php?id=10724&sid=4fb980f57c06d3321068c7aa4c4e24cb
You can see at the bottom of the blue (std) curve there is a gentle rise. I'd say that this takes up the valve clearance and gives a smooth transition into the proper lift part of the profile. Where the 'performance' cam has a sharp transition so will be harsher in operation. I'm wondering if the 'performance' cam would be better running slightly tighter valve clearances than std to take up a bit of the slack and lessen the impact on and off the profile?
Nick
[Edited on 23/7/12 by Nickp]
Nickp
posted on 23/7/12 at 05:19 PM Reply With Quote
No opinions?
AntonUK
posted on 23/7/12 at 08:12 PM Reply With Quote
I'm not too experienced on cam profiles etc, but I was under the impression that this is typical of a re-ground cam?
Build Photos Here
Nickp
posted on 23/7/12 at 08:39 PM Reply With Quote
You may well be right. Grinders don't want to waste material having nice soft opening / closing ramps when they can get more lift without them.
posted on 23/7/12 at 09:01 PM Reply With Quote
ISTR them referred to as "quietening ramps" from which I would assume main purpose is to reduce tappet noise
chillis
posted on 23/7/12 at 10:35 PM Reply With Quote
It has a lot to do with how you measure it and the equipment used, also have you been given profile details OR valve event details?
I've measured many cam profiles over the years and they rarely match up to the quoted figures even the same profile from different grinders can differ quite a bit for allegedly the same lift and duration, also the yanks measure a different way again.
40 deg does seem a lot just for the ramp. Is that crank or cam degrees?
ashg
posted on 23/7/12 at 11:12 PM Reply With Quote
I notice the file in the link is from guy crofts website. Is it a cam supplied by him? if so I wouldn't worry the chap is a legend when it comes to building engines. He did the head on one of my lancias years back cost a small fortune but boy did it transform the car once it was all back together and mapped.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Nickp
posted on 24/7/12 at 06:29 AM Reply With Quote
It was 40deg of cam rotation for each ramp.
Nickp
posted on 24/7/12 at 06:31 AM Reply With Quote
The cam's if definately not from Guy Croft. He is a legend when it comes to the Twin Cam, but if you even mention regrinds on his website then prepare for the worst!! Guess how I know?
Nickp
posted on 24/7/12 at 06:42 AM Reply With Quote
But is this the purpose of them or is it a result of their design to smooth the transition out? I'm not sure.
chillis
posted on 24/7/12 at 10:03 AM Reply With Quote
I should have read your post properly first. you are using reground cams yes?
A reground or to put it properly reprofiled cam has a new profile ground into what ever material was already there. Since the new profile really wants more metal than you had to start with there are compromises. One of those it going to be the base circle diameter and another the length of the ramps.
There are different ramp designs for hydraulic and mechanical tappets. Noise would be one consideration and valve gear wear another. The longer the ramp the gentler it is.
I guess you pay your money and take you pick.
When possible I try to avoid reprofiled cams they can be a false economy, that said there are plenty of bmc mini boys using them.
Nickp
posted on 24/7/12 at 10:57 AM Reply With Quote
Yes, unfortunately the 'Twinks' cams aren't blessed with an excess of material. The base circle of these has been taken down from 26.4mm to 24mm which appears to be on the limit, but allows for the extra lift and duration. Hopefully these are mild enough to work on the std castings but wild enough to make a difference, if you know what I mean?
They were done by a QED employee for his own engine apparently and are to their Q420 profile for the Lotus Twin Cam. Supposedly they made 160BHP in a modified 1600, which sounds a tad optimistic to me.
posted on 24/7/12 at 11:46 AM Reply With Quote
If you plot the acceleration of the lifter throughout the cam profile, there is surprisingly little increase for the performance cam vs the original, so I think it will be ok. Are you uprating the valve springs or using originals?
Nickp
posted on 24/7/12 at 12:01 PM Reply With Quote
Pretty much what I thought, it's about 10% up everywhere so not too mad at all. It's already got Isky race springs in there as I planned to put hotter cams in at some point after I originally built the engine. I'm probably gonna have to take the head off again to check the valve to piston clearances as they're pretty tight with the std cams.
