jps
| posted on 7/8/12 at 08:28 AM |
Type E Gearbox?
The donor Sierra I am intending to take my (Pinto) engine and gearbox from seems to have a Type E gearbox fitted (4 speed - reverse over to the left
and forward). Has anyone used a Type E in a Locost build? Are there any problems specific to using a Type E?
I also have an MT75 gearbox - and a chassis built to fit it - so am wondering whether I will be better off using that instead perhaps?
James
| posted on 7/8/12 at 08:49 AM |
Is it a very old Sierra? It's either that or it's had a replacement box fitted!
Personally, as a choice of the 2, I would fit the MT75. If you're going to be driving at any decent sort of speed I'd be surprised if you
didn't want the 5th gear!
James
- Muhammad Ali
jps
| posted on 7/8/12 at 08:53 AM |
It's a C reg 1.6 EMAX L - so yep, an old, and low spec, one!
To be fair the Sierra will trot along at 70mph with no problems at all - and I can't imagine i'll be wanting to take my kit car to
ridiculous top speeds....
loggyboy
| posted on 7/8/12 at 09:15 AM |
If the chassis is spec for it go for the MT75, at least that way if you change your use and want to rag it on track, or sell it to some one who will
track it, you can promote it has having the more recent, durable g/box.
No real good reason to keep the typeE apart from a minmal weight difference, which might even be negated by the all alloy casing of the mt75.
Mistral Motorsport
r1_pete
MT75 is a stronger box, 5 speed, easy to relocate the gear lever, for my money there is no question use it.
TimC
| posted on 7/8/12 at 10:25 AM |
But - the Type E is lighter (by quite a bit). This is why only one or two Locost racers use a Type 9 with their X-flows. Nobidy will be using the
heavy MT75.
