ali f27
| posted on 10/8/12 at 08:05 AM |
raceline housing
Hi my raceline oil filter housing has just arrived i cant figure out what thread the tapping for pressure gauge is standard duratec will not screw in
Cheers Ali
redeye
| posted on 10/8/12 at 08:36 AM |
I believe it is m12
You probably need to buy an adapter to allow the duratec switch to fit.
Edited to say: The standard duratec fitting is only a switch, you will need an T piece adapter and fit a pressure sensor and switch.
For mine I used a 20psi switch from JJC
The 15psi is the preffered since the duratec idles at low pressure when hot, but no body seems to have them in stock at the moment.
[Edited on 10/8/12 by redeye]
big-vee-twin
| posted on 10/8/12 at 03:12 PM |
Its m12 1.5 you need to fit an adapter tee to allow pressure switch and pressure meter to be fitted.
Then you will need an adapter from the raceline thread to ford thread.
I ended up buying a new pressure switch to fit the thread as most of the adapter tees have a 1/8th ntp and m12 1.5mm thread.
I bough a Lotus Elise switch Link
Appear to be back in stock redeye, I know you have been after one for a while
http://www.triangleltd.com
